.NET
Valued Contributor
chockalingam
Message 1 of 13 (432 Views)
Change Color, Line Type and Line weight without selecting any objects
432 Views, 12 Replies
03-09-2012 07:57 PM
I am trying to Change the Color, Line Type and Line weight in Properties Pallete without selecting any objects, but i don't know how to do this.
Jeff_M
Message 2 of 13 (394 Views)
Re: Change Color, Line Type and Line weight without selecting any objects
03-09-2012 10:00 PM in reply to: chockalingam
Those are controlled by the drawing's Current sysvars.
CECOLOR
CELTYPE
CELWEIGHT
Valued Contributor
chockalingam
Message 3 of 13 (390 Views)
03-09-2012 10:06 PM in reply to: chockalingam
Can you guide me, to use this in .net code
Valued Mentor
KerryBrown
Message 4 of 13 (382 Views)
03-09-2012 10:14 PM in reply to: chockalingam
Untested
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
// AcadApp.SetSystemVariable(string name, object value)
	AcadApp.SetSystemVariable("CECOLOR", "BYLAYER")
	AcadApp.SetSystemVariable("CELTYPE", "ByLayer")
	AcadApp.SetSystemVariable("CELWEIGHT", -1)
 Regards
class keyThumper<T> : Lazy<T>;      another  Swamper
Valued Contributor
chockalingam
Message 5 of 13 (379 Views)
03-09-2012 10:28 PM in reply to: chockalingam
On using the above code,
AcadApp.SetSystemVariable("CECOLOR", "BYLAYER")- Results No Change
AcadApp.SetSystemVariable("CELTYPE", "ByLayer")- Results in "eInvalidInput" error
AcadApp.SetSystemVariable("CELWEIGHT", -1)- Results in "eInvalidInput" error
Valued Mentor
KerryBrown
Message 6 of 13 (368 Views)
03-09-2012 10:55 PM in reply to: chockalingam
Works for me. ... see attached piccy.
Valued Contributor
chockalingam
Message 7 of 13 (363 Views)
03-09-2012 11:01 PM in reply to: chockalingam
I don't know why it is not working for me.....
But i got the solution in another way, my solution code follows,
Using lock As DocumentLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
Using acTrans As Transaction = acDoc.Database.TransactionManager.StartTransaction()
acDoc.Database.Celweight = LineWeight.LineWeight015
acDoc.Database.Cecolor = Autodesk.AutoCAD.Colors.Color.FromColor(Color.Red)
Dim acLineTypTbl As LinetypeTable
acLineTypTbl = acTrans.GetObject(acDoc.Database.LinetypeTableId, OpenMode.ForRead)
Dim sLineTypName As String = "Continuous"
If acLineTypTbl.Has(sLineTypName) = True Then
'' Set the linetype Center current
acDoc.Database.Celtype = acLineTypTbl(sLineTypName)
'' Save the changes
End If
acTrans.Commit()
End Using
End Using
Valued Contributor
chockalingam
Message 8 of 13 (357 Views)
03-09-2012 11:15 PM in reply to: chockalingam
But the Only Issue in above code is we can't reback to "ByLayer"
Valued Mentor
KerryBrown
Message 9 of 13 (351 Views)
03-09-2012 11:35 PM in reply to: chockalingam
Please clarify your last post. ??
And the code you posted is different to your initial question  ... but I see how I could confuse your intent.
Alfred.NESWADBA
Message 10 of 13 (347 Views)
03-09-2012 11:47 PM in reply to: chockalingam
Why not, this code does not Work?
acDoc.Database.Celtype = "byLayer"
- alfred -
Alfred NESWADBA
You are not logged in.
Ask the Community
