.NET
Amremad
Message 1 of 14 (552 Views)
Chang SelectionFilter during GetSelection
552 Views, 13 Replies
06-24-2013 03:16 AM
hi every one
i added an keyword with GetSelection  using PromptSelectionOptions , this keyword can detrimne ablock name after run my selection
Dim AcSelResult As PromptSelectionResult = Application.DocumentManager.MdiActiveDocument.Editor.GetSelection(AcSelOption, AcSelFtr)
 now how can i reload my selection by new block name , without end command
cause my current selection take old selection filter ,
i hope you understand me
ADN Support Specialist
fenton.webb
Message 2 of 14 (519 Views)
Re: Chang SelectionFilter during GetSelection
06-24-2013 09:59 AM in reply to: Amremad
when the keyword is pressed, simply update your filter, then restart the GetSelection with the new filter. Or am I misunderstanding you?
Fenton Webb
Developer Technical Services
Autodesk Developer Network
Amremad
Message 3 of 14 (497 Views)
06-25-2013 12:03 AM in reply to: fenton.webb
yes mr fenton that what i want ,
but how can i reload my selection after changing the filter of selection ???
Valued Mentor
DiningPhilosopher
Message 4 of 14 (473 Views)
06-25-2013 01:37 PM in reply to: Amremad
You can't alter a selection filter while selection is in progress, and there is no way to restart with the previously-selected objects to allow more interactive selection.
You can use the Editor's SelectionAdded event to filter a selection using more dynamic criteria.
fenton.webb
Message 5 of 14 (467 Views)
06-25-2013 02:37 PM in reply to: DiningPhilosopher
Perhaps you could try SendStringToExecute to start your command again passing the previous selection set as a LISP ss variable
Fenton Webb
fenton.webb
Message 6 of 14 (465 Views)
06-25-2013 02:37 PM in reply to: fenton.webb
You could also use the acedSSSetFirst() with a UsePickset defined command to reselect the selection
Fenton Webb
Amremad
Message 7 of 14 (444 Views)
This is my completely code
06-26-2013 12:03 AM in reply to: DiningPhilosopher
thank you mr diningphilosopher for helping
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Public NotInheritable Class ChangeBlocks
    Private Shared MObject As String
    Private Shared Factor As Double
    Private Shared Modification As String
    Private Shared Type As String
    Private Shared TypedValues(0) As TypedValue
    Private Shared AcSelFtr As SelectionFilter
    Private Shared LFormat As String
    Public Shared Sub ChengeBlock()
        MObject = GetSetting("AMR LISP", "Chenge Block", "Object", "ALL")
        Factor = GetSetting("AMR LISP", "Chenge Block", "Factor", "0")
        Type = GetSetting("AMR LISP", "Chenge Block", "Type", "Text")
        LFormat = GetSetting("AMR LISP", "Check Level", "Format", "0.00")
        ' create selection filter with typedvalues
        'Dim TypedValues(0) As TypedValue
        If MObject = "All" Then
            TypedValues.SetValue(New TypedValue(DxfCode.Start, "INSERT"), 0)
        Else
            TypedValues.SetValue(New TypedValue(DxfCode.BlockName, MObject), 0)
        End If
        AcSelFtr = New SelectionFilter(TypedValues)
        'create keywords options for selection
        Dim AcSelOption As PromptSelectionOptions = New PromptSelectionOptions
        AcSelOption.Keywords.Add("Object")
        AcSelOption.Keywords.Add("FActor")
        AcSelOption.Keywords.Add("FOrmat")
        AcSelOption.Keywords.Add("Type")
        AcSelOption.MessageForAdding = (vbLf & "Select Object(s) or " & AcSelOption.Keywords.GetDisplayString(True))
        AcSelOption.Keywords.Default = "Object"
        AddHandler AcSelOption.KeywordInput, AddressOf handle_KeywordInput
        Dim Tr As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
        If AcSelResult.Status = PromptStatus.OK Then
            If Type = "Text" Then
                If ChangeText(AcSelResult.Value) = False Then
                    Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & "invalid operation, try again")
                End If
            Else
                If EditScale(AcSelResult.Value) = False Then
                End If
            End If
        End If
        Tr.Commit()
        Tr.Dispose()
        Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & "done")
    End Sub
    Private Shared Function ChangeText(MySelSet As SelectionSet) As Boolean
        If MySelSet IsNot Nothing Then
            For Each BlKID In MySelSet.GetObjectIds()
                Dim BlkRef As BlockReference = Tr.GetObject(BlKID, OpenMode.ForWrite)
                If BlkRef.AttributeCollection.Count > 0 Then
                    Dim objId As ObjectId = BlkRef.AttributeCollection.Item(0)
                    Dim attRef As AttributeReference = Tr.GetObject(objId, OpenMode.ForWrite)
                    Dim Value As Double = Val(attRef.TextString) + Factor
                    If Value = 0 Then
                        attRef.TextString = "±" & Format(Value, LFormat)
                    ElseIf Value > 0 Then
                        attRef.TextString = "+" & Format(Value, LFormat)
                    ElseIf Value < 0 Then
                        attRef.TextString = Format(Value, LFormat)
                    End If
                End If
            Next
        End If
        Tr.Commit()
        Tr.Dispose()
        Return True
    End Function
    Private Shared Function EditScale(MySelSet As SelectionSet) As Boolean
                If Factor > 0 Then
                    BlkRef.TransformBy(Matrix3d.Scaling(Factor, BlkRef.Position))
                Else
                    Return False
                End If
            Next
        End If
        Tr.Commit()
        Tr.Dispose()
        Return True
    End Function
    Private Shared Sub handle_KeywordInput(ByVal sender As Object, ByVal e As SelectionTextInputEventArgs)
        Select Case e.Input
            Case "Object"
                Dim Trans As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
                Dim AcEntOption As PromptEntityOptions = New PromptEntityOptions(vbLf & "Select base object")
                AcEntOption.Keywords.Add("All")
                AcEntOption.Keywords.Add(MObject)
                AcEntOption.Keywords(1).Visible = False
                AcEntOption.Keywords.Default = MObject
                AcEntOption.SetRejectMessage(vbLf & "You must pick a block , try again ...")
                AcEntOption.AddAllowedClass(GetType(BlockReference), True)
                Dim AcEntResult As PromptEntityResult = Application.DocumentManager.MdiActiveDocument.Editor.GetEntity(AcEntOption)
                If AcEntResult.Status = PromptStatus.OK Then
                    Dim Obj As DBObject = Trans.GetObject(AcEntResult.ObjectId, OpenMode.ForRead)
                    If TypeOf (Obj) Is BlockReference Then
                        Dim Source As BlockReference = Obj
                        MObject = Source.Name
                        SaveSetting("AMR LISP", "Chenge Block", "Object", MObject)
                        'TypedValues.SetValue(New TypedValue(DxfCode.Start, MObject), 0)
                        'AcSelFtr = New SelectionFilter(TypedValues)
                    End If
                ElseIf AcEntResult.Status = PromptStatus.Keyword Then
                    Select Case AcEntResult.StringResult
                        Case "All"
                            MObject = "All"
                            'TypedValues.SetValue(New TypedValue(DxfCode.BlockName, MObject), 0)
                    End Select
                Else
                    Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & "you are selected unsupported object")
                End If
                Trans.Commit()
                Trans.Dispose()
            Case "FActor"
L2:             Dim AcDblOption As PromptDoubleOptions = New PromptDoubleOptions(vbLf & "Enter the calculation unit (Meter Unit) ")
                AcDblOption.AllowNone = False
                AcDblOption.DefaultValue = Factor
                    AcDblOption.AllowNegative = True
                Else
                    AcDblOption.AllowNegative = False
                End If
                Dim AcDblResult As PromptDoubleResult = Application.DocumentManager.MdiActiveDocument.Editor.GetDouble(AcDblOption)
                If AcDblResult.Status = PromptStatus.OK Then
                    If Type = "Size" And AcDblResult.Value <= 0 Then
                        Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & "Value must be positive.")
                        GoTo L2
                    End If
                    Factor = AcDblResult.Value
                    SaveSetting("AMR LISP", "Chenge Block", "Factor", Factor)
                Else
                End If
            Case "Type"
                Dim AcKwrdOption2 As PromptKeywordOptions = New PromptKeywordOptions(vbLf & "Which method you will use  [Text/Size] : ", "Text Size")
                AcKwrdOption2.Keywords.Default = Type
                Dim AcKwrdResult2 As PromptResult = Application.DocumentManager.MdiActiveDocument.Editor.GetKeywords(AcKwrdOption2)
                If AcKwrdResult2.Status = PromptStatus.OK Then
                    Type = AcKwrdResult2.StringResult
                    SaveSetting("AMR LISP", "Chenge Block", "Type", Type)
                End If
            Case "FOrmat"
                Dim AcStrOption As PromptStringOptions = New PromptStringOptions("Enter text format that you want :")
                AcStrOption.DefaultValue = LFormat
                Dim AcStrResult As PromptResult = Application.DocumentManager.MdiActiveDocument.Editor.GetString(AcStrOption)
                If AcStrResult.Status = PromptStatus.OK Then
                    LFormat = AcStrResult.StringResult
                    SaveSetting("AMR LISP", "Chenge Block", "Format", LFormat)
                End If
        End Select
    End Sub
End Class
this code can edit all block size , or block attributes text
my problem if the user while selection change the block name , so i need to apply the new filter to current selection ,
or cancel selection by code, or any solution to fix this problem
Valued Mentor
DiningPhilosopher
Message 8 of 14 (429 Views)
Re: This is my completely code
06-26-2013 08:43 AM in reply to: Amremad
Sorry, no time to pick apart that code, but as I mentioned, the best way to solve the problem is to use the Editor's SelectionAdded event.
Otherwise, the link below shows a kludge that allows you to use GetSelection() and start with an existing selection set that a user can edit (add to or remove from):
       http://www.theswamp.org/index.php?topic=43970.0
Amremad
Message 9 of 14 (397 Views)
06-27-2013 06:44 AM in reply to: DiningPhilosopher
Thanks MR. DiningPhilosopher for your help
but SelectionAdded event. doesn't work what i want ,
i neet to update filter of currect selection .. Understand me?
Valued Mentor
DiningPhilosopher
Message 10 of 14 (386 Views)
06-27-2013 04:24 PM in reply to: Amremad
Sorry, you're mistaken.  Perhaps you don't understand how the event works.
You filter each object as it is selected, using any criteria you want.
You can change the filter criteria at any time.
You are not logged in.
Ask the Community
