.NET
Valued Contributor
sszabo
Message 21 of 30 (1,826 Views)
Re: Catastrophic failure HRESULT: 0x8000FFFF (E_UNEXPECTED)
01-29-2013 02:20 PM in reply to: tonofsteel
Thanks a lot, I am getting the same result.  It's probably something with my autocad version/installation.  I also noticed that every now and then it works in particular when I step through the debugger so I tried adding sleep delays with no results so far.  Again, thanks for your help.
Valued Contributor
tonofsteel
Message 22 of 30 (1,822 Views)
01-29-2013 02:49 PM in reply to: sszabo
Try this version
I got rid of the line that I added previously and change the hostService method to:
   Public Sub hostService(ByVal _hostIP As String, ByVal _port As String)
        Dim wcfEndpoint As String = String.Format("{0}://{1}:{2}/{3}", m_DefaultProtocol, _hostIP, _port, m_DefaultService)
        Try
            Dim wcfSelectSingleton As New wcfSelectItems
            Dim baseAddress As Uri = New Uri(wcfEndpoint)
            m_serviceHost = New ServiceHost(wcfSelectSingleton, baseAddress)
This works for me.  I am thinking that by creating new here and passing it into the ServiceHost that the property gets set properly.  Try it and see if any different for you.
Valued Contributor
sszabo
Message 23 of 30 (1,815 Views)
01-29-2013 03:32 PM in reply to: tonofsteel
with your current attachment as is I am getting this error on the same line (activeDoc =)
Unable to cast COM object of type 'System.__ComObject' to interface type 'Autodesk.AutoCAD.Interop.AcadDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{0EB66A59-8FF4-410B-B697-8813116B2C5F}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
the only way I can get it to run is under the VS 2010 debugger.  It runs as expected with or without breakpoints set.  I think it must be something with AutoCAD 2013. I am running build G.114 SP 1.1 on Windows 7 but I even tried G.55 on Windows XP (no SP) with the same exact result.
Valued Contributor
tonofsteel
Message 24 of 30 (1,810 Views)
01-29-2013 03:39 PM in reply to: sszabo
Are you using the attached project as-is?  That line should be commented out:
Public Class wcfSelectItems
    Implements ISelectItems
    Private log As Logger = LogManager.GetCurrentClassLogger
    Public Sub SelectItems() Implements ISelectItems.SelectItems
        log.Info("This will crash")
        DoSelection()
    End Sub
    Public activeDoc As Document = MgdAcApplication.DocumentManager.MdiActiveDocument
    Public Sub DoSelection()
        Try
            'activeDoc = MgdAcApplication.DocumentManager.MdiActiveDocument
            Using acDocLck As DocumentLock = activeDoc.LockDocument()
                Dim td As AcadDocument = DocumentExtension.GetAcadDocument(activeDoc)
                Dim ssetObj As AcadSelectionSet = td.SelectionSets.Add("SSALL0")   ' creates named selection set
                ssetObj.Select(AcSelect.acSelectionSetAll)
                log.Trace("We have a selection of size = {0}", ssetObj.Count)
                activeDoc.Editor.WriteMessage("We have a selection of size = {0}", ssetObj.Count)
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("We have a selection of size = " & ssetObj.Count.ToString())
                Try
                    For Each ent As AcadEntity In ssetObj
                        log.Trace("{0}", ent.ObjectName)
                    Next
                Catch
                    log.Error("This is the crash: '{0}'", Err.Description)
                End Try
            End Using
        Catch
            log.Error(Err.Description)
        End Try
    End Sub
End Class
#End Regio
Valued Contributor
tonofsteel
Message 25 of 30 (1,804 Views)
01-29-2013 04:11 PM in reply to: sszabo
If you take the DLL files from the debug folder from the last project I uploaded and try to netload that does it work?
Valued Contributor
sszabo
Message 26 of 30 (1,790 Views)
01-30-2013 04:17 AM in reply to: tonofsteel
Yeah I know it sounds weird but it doesn't.  At least we know that the code itself is OK thanks to your help but there must be some weird issue with my version of autocad because no matter what build on what windows version I try it doesn't work.
Valued Contributor
sszabo
Message 27 of 30 (1,778 Views)
01-30-2013 12:38 PM in reply to: sszabo
Just a followup to this thread:
The 1st post still stands.  As far as I know this does not work in ACAD 2013 it might work in electric.
The issue is that .NET is throwing an exception whenever the code reaches MoveNext in a loop through collection items such as this:
                Try
                    Next
                Catch
                    log.Error("This is the crash: '{0}'", Err.GetException.ToString)
                End Try
 The detailed exception is as follows:
This is the crash: 'System.Runtime.InteropServices.COMException (0x8000FFFF): Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
   at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
   at System.Runtime.InteropServices.CustomMarshalers.EnumeratorViewOfEnumVariant.MoveNext()
   at ClassLibrary1.wcfSelectItems.DoSelection() in H:\_TEST\ClassLibrary2\Class1.vb:line 85'
Throughout this thread there was a lot of trial and error mainly involving the active document and how to initialize it in the context of new WCF requests.  Since yesterday I learned a great deal about this topic thanks to tonofsteel and Paul Schelppy's excelent video (http://au.autodesk.com/?nd=event_class&jid=610987&session_id=7182) and I am ready to share but it's unrelated to this problem.
I also found that the code in post 1 runs perfectly well under the VS 2010 debugger.  I still don't know what's that all about.
If anyone out there knows a solution please let me know.
Moderator
Alexander.Rivilis
Message 28 of 30 (1,770 Views)
01-30-2013 02:43 PM in reply to: sszabo
I'm not sure that this code is thread-safe. The AutoCAD API's do not support multithreading. You should only call the API functions from the main thread:
Use Thread for background processing
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
sszabo
Message 29 of 30 (1,755 Views)
01-31-2013 08:36 AM in reply to: Alexander.Rivilis
Alexander.Rivilis, thanks for the link, I'll check that out, although I was under the impression that when I set ConcurrencyMode to Single in a WCF server that's what it does: the host and the Service execute in the same thread.  I can verify if that's true fro sure by dumping the native thread ids from both, I'll post my findings.
Valued Contributor
sszabo
Message 30 of 30 (1,732 Views)
02-02-2013 10:34 AM in reply to: Alexander.Rivilis
To wrap this thread up, I was finally successful hosting and starting a functional WCF server inside the ACAD process and I can call functions that expose core acad functionality to any program running anywhere on the network.  The solution came as a combination of Adam Nagy's example in the reply thanks to Alexander.Rivilis  that solved the core multithreading problem and Paul Shleppy's excellent video from AU that taught me how to pass objects to a custom ServiceHost class.
Here is the full solution for anyone out there who's trying to accomplish something similar, please give everyone who contributed to it credit for it by response/kudos , thanks.
Imports System.Windows.Forms
Imports System.ServiceModel
Imports System.ServiceModel.Description
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports MgdAcApplication = Autodesk.AutoCAD.ApplicationServices.Application
Public Class AcServiceHost
    Inherits ServiceHost
    Private _ctrl As clsControl = Nothing
    Public Sub New(ByVal serviceType As Type, ByVal endpoint As Uri, ByVal ctrl As clsControl)
        MyBase.New(serviceType, endpoint)
        _ctrl = ctrl
    End Sub
    Public ReadOnly Property SyncControl As clsControl
        Get
            Return _ctrl
        End Get
    End Property
End Class
<ServiceContract()>
Public Interface ISelectItems
    <OperationContract()>
    Sub SelectItems()
End Interface
<ServiceBehavior(InstanceContextMode:=InstanceContextMode.Single, ConcurrencyMode:=ConcurrencyMode.Single)>
    Private myControl As clsControl = Nothing
        Try
            Dim context As OperationContext = OperationContext.Current
            Dim acHost As AcServiceHost = TryCast(context.Host, AcServiceHost)
            myControl = acHost.SyncControl
            myControl.SelectItems()
        Catch
        End Try
    End Sub
End Class
Public Class clsControl
    Inherits Control
    Implements IDisposable
    Private Delegate Sub DoSynchronizedSelection()
    Public ed As Editor = activeDoc.Editor
        If InvokeRequired Then
            Invoke(New DoSynchronizedSelection(AddressOf DoSelection))
        Else
            DoSelection()
        End If
    End Sub
    Public Sub logMessage(ByVal format As String, ByVal ParamArray args As Object())
        Dim msg As String = format
        Try
            msg = String.Format(format, args)
        Catch
        End Try
        ed.WriteMessage(vbLf + msg)
    End Sub
    'Do selection routine, exact same as above.  This one works:
        Try
                Dim ssetObj As AcadSelectionSet = td.SelectionSets.Add("SSALL" + DateTime.Now.ToString)   ' creates named selection set
                logMessage("We have a selection of size = {0}", ssetObj.Count)
                Try
                        logMessage("{0}", ent.ObjectName)
                    Next
                Catch
                    logMessage("This is the crash: '{0}'", Err.GetException.ToString)
                End Try
            End Using
        Catch
            logMessage("EX 1. {0}", Err.GetException.ToString)
        End Try
    End Sub
End Class
Public Class clsSelectedItems
    Implements IExtensionApplication
    Public m_DefaultService As String = "ISelectItems"
    Public m_DefaultIP As String = "127.0.31.173"
    Public m_DefaultPort As String = "7101"
    Public m_DefaultProtocol As String = "http"
    Private m_serviceHost As ServiceHost = Nothing
    Shared syncCtrl As clsControl = Nothing
    Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
        syncCtrl = New clsControl()
        syncCtrl.CreateControl()
        hostService(m_DefaultIP, m_DefaultPort)
    End Sub
    Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
        If Not m_serviceHost Is Nothing Then
            m_serviceHost.Close()
        End If
    End Sub
    ' Set up a WCF service endpoint and start service
        Try
            m_serviceHost = New AcServiceHost(GetType(wcfSelectItems), baseAddress, syncCtrl)
            Dim binding = CreateNewHttpBinding(GetType(wcfSelectItems).FullName)
            m_serviceHost.AddServiceEndpoint(GetType(ISelectItems), binding, m_DefaultService)
            Dim smb As New ServiceMetadataBehavior()
            smb.HttpGetEnabled = True
            m_serviceHost.Description.Behaviors.Add(smb)
        Catch
            syncCtrl.logMessage("EX 2. {0}", Err.GetException.ToString)
        End Try
        m_serviceHost.Open()
        syncCtrl.logMessage("Listening on {0}", wcfEndpoint)
    End Sub
    'We avoid using config files for now:
    Private Shared Function CreateNewHttpBinding(ByVal name As String) As WSHttpBinding
        Dim result As New WSHttpBinding
        result.Name = name
        result.OpenTimeout = New TimeSpan(0, 1, 0)
        result.ReceiveTimeout = New TimeSpan(0, 10, 0)
        result.SendTimeout = New TimeSpan(0, 1, 0)
        result.BypassProxyOnLocal = False
        result.TransactionFlow = False
        result.HostNameComparisonMode = HostNameComparisonMode.StrongWildcard
        result.MaxBufferPoolSize = 2147483647
        result.MaxReceivedMessageSize = 2147483647
        result.MessageEncoding = WSMessageEncoding.Text
        result.TextEncoding = System.Text.Encoding.UTF8
        result.UseDefaultWebProxy = True
        result.AllowCookies = False
        result.ReaderQuotas.MaxStringContentLength = 2147483647
        result.ReaderQuotas.MaxDepth = 12
        result.ReaderQuotas.MaxArrayLength = 16384
        result.ReaderQuotas.MaxBytesPerRead = 4096
        result.ReaderQuotas.MaxNameTableCharCount = 16384
        result.ReliableSession.Ordered = False
        result.ReliableSession.InactivityTimeout = New TimeSpan(0, 10, 0)
        result.ReliableSession.Enabled = False
        result.Security.Mode = SecurityMode.None
        result.Security.Transport.ClientCredentialType = HttpClientCredentialType.None
        result.Security.Message.ClientCredentialType = MessageCredentialType.None
        Return (result)
    End Function
End Class
You are not logged in.
Ask the Community
