.NET
Valued Contributor
sszabo
Message 1 of 30 (837 Views)
Catastrophic failure HRESULT: 0x8000FFFF (E_UNEXPECTED)
837 Views, 29 Replies
01-29-2013 05:36 AM
I am trying to run acad code from a WCF service in process.  I get most everything work just fine but for some reason I get this cryptic error when I try to loop through a selection set of AcadEntity objects.  The weird part is that if I place the same loop in a simple IExtensionApplication command it works fine.
Does anyone have any suggestions how to make this work?  I assume something to do with wcf service behavior/acad threading model but not sure what.
Here is the full source code, note that I am not using Editor.WriteMessage because that's one of the things I cannot get working from WCF so I am relying on NLog to generate the output on the bottom of this message. If you have an idea how to make Editor.WriteMessage work from WCF I'd appreciate your help as well.
Thanks in advance,
Steve
Imports System.ServiceModel
Imports System.ServiceModel.Description
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports Autodesk.AutoCAD.ApplicationServices
Imports MgdAcApplication = Autodesk.AutoCAD.ApplicationServices.Application
Imports NLog
#Region "WCF SERVICE"
<ServiceContract()>
Public Interface ISelectItems
    <OperationContract()>
    Sub SelectItems()
End Interface
<ServiceBehavior(InstanceContextMode:=InstanceContextMode.Single, ConcurrencyMode:=ConcurrencyMode.Single)>
Public Class wcfSelectItems
    Implements ISelectItems
    Private log As Logger = LogManager.GetCurrentClassLogger
    Public Sub SelectItems() Implements ISelectItems.SelectItems
        log.Info("This will crash")
        DoSelection()
    End Sub
    Public activeDoc As Document = MgdAcApplication.DocumentManager.MdiActiveDocument
    Public Sub DoSelection()
        Try
            Using acDocLck As DocumentLock = activeDoc.LockDocument()
                Dim td As AcadDocument = DocumentExtension.GetAcadDocument(activeDoc)
                Dim ssetObj As AcadSelectionSet = td.SelectionSets.Add("SSALL0")   ' creates named selection set
                ssetObj.Select(AcSelect.acSelectionSetAll)
                log.Trace("We have a selection of size = {0}", ssetObj.Count)
                Try
                    For Each ent As AcadEntity In ssetObj
                        log.Trace("{0}", ent.ObjectName)
                    Next
                Catch
                    log.Error("This is the crash: '{0}'", Err.Description)
                End Try
            End Using
        Catch
            log.Error(Err.Description)
        End Try
    End Sub
End Class
#End Region
Public Class clsSelectedItems
    Implements IExtensionApplication
#Region "ACAD COMMAND"
    <CommandMethod("DoSelection")> _
    Public Sub DoSelection_Method()
        log.Info("This is OK")
        DoSelection()
    End Sub
#End Region
    Public m_DefaultService As String = "ISelectItems"
    Public m_DefaultIP As String = "127.0.0.1"
    Public m_DefaultPort As String = "7200"
    Public m_DefaultProtocol As String = "http"
    Private m_serviceHost As ServiceHost = Nothing
    Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
        hostService(m_DefaultIP, m_DefaultPort)
    End Sub
    Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
        If Not m_serviceHost Is Nothing Then
            m_serviceHost.Close()
        End If
    End Sub
    'Do selection routine, exact same as above.  This one works:
        Try
                Dim ssetObj As AcadSelectionSet = td.SelectionSets.Add("SSALL1")   ' creates named selection set
                Try
                    Next
                Catch
                End Try
            End Using
        Catch
        End Try
    End Sub
    ' Set up a WCF service endpoint and start service
    Public Sub hostService(ByVal _hostIP As String, ByVal _port As String)
        Dim wcfEndpoint As String = String.Format("{0}://{1}:{2}/{3}", m_DefaultProtocol, _hostIP, _port, m_DefaultService)
        Try
            Dim baseAddress As Uri = New Uri(wcfEndpoint)
            m_serviceHost = New ServiceHost(GetType(wcfSelectItems), baseAddress)
            Dim binding = CreateNewHttpBinding(GetType(wcfSelectItems).FullName)
            m_serviceHost.AddServiceEndpoint(GetType(ISelectItems), binding, "IAcadInProc")
            Dim smb As New ServiceMetadataBehavior()
            smb.HttpGetEnabled = True
            m_serviceHost.Description.Behaviors.Add(smb)
        Catch ex As Exception
            log.Error("EX 2. {0}", ex.ToString)
        End Try
        m_serviceHost.Open()
        log.Info("Listening on {0}", wcfEndpoint)
    End Sub
    'We avoid using config files for now:
    Private Shared Function CreateNewHttpBinding(ByVal name As String) As WSHttpBinding
        Dim result As New WSHttpBinding
        result.Name = name
        result.OpenTimeout = New TimeSpan(0, 1, 0)
        result.ReceiveTimeout = New TimeSpan(0, 10, 0)
        result.SendTimeout = New TimeSpan(0, 1, 0)
        result.BypassProxyOnLocal = False
        result.TransactionFlow = False
        result.HostNameComparisonMode = HostNameComparisonMode.StrongWildcard
        result.MaxBufferPoolSize = 2147483647
        result.MaxReceivedMessageSize = 2147483647
        result.MessageEncoding = WSMessageEncoding.Text
        result.TextEncoding = System.Text.Encoding.UTF8
        result.UseDefaultWebProxy = True
        result.AllowCookies = False
        result.ReaderQuotas.MaxStringContentLength = 2147483647
        result.ReaderQuotas.MaxDepth = 12
        result.ReaderQuotas.MaxArrayLength = 16384
        result.ReaderQuotas.MaxBytesPerRead = 4096
        result.ReaderQuotas.MaxNameTableCharCount = 16384
        result.ReliableSession.Ordered = False
        result.ReliableSession.InactivityTimeout = New TimeSpan(0, 10, 0)
        result.ReliableSession.Enabled = False
        result.Security.Mode = SecurityMode.None
        result.Security.Transport.ClientCredentialType = HttpClientCredentialType.None
        result.Security.Message.ClientCredentialType = MessageCredentialType.None
        Return (result)
    End Function
End Class
OUTPUT:
Info    clsSelectedItems     Listening on http://127.0.0.1:7200/ISelectItems
Info    wcfSelectItems       This will crash
Trace    wcfSelectItems     We have a selection of size = 200
Error    wcfSelectItems       This is the crash: 'Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))'
Info    clsSelectedItems       This is OK
Trace    clsSelectedItems       We have a selection of size = 200
Trace    clsSelectedItems       AcDbText
Trace    clsSelectedItems       AcDbViewport
% <--------------ETC. CUT------------->%
Valued Contributor
tonofsteel
Message 2 of 30 (815 Views)
Re: Catastrophic failure HRESULT: 0x8000FFFF (E_UNEXPECTED)
01-29-2013 08:10 AM in reply to: sszabo
How do you get the first example that does not work to run?  It looks like you might be trying to use a mix of ObjectARX .NET and COM and run out of process.
If you are not netloading the assembly in-process then the ObjectARX .NET will not work.
Change the first example to only use COM, or do as you did in the second and get your service running through the initialize method to allow you to use the .NET API.
Valued Contributor
sszabo
Message 3 of 30 (811 Views)
01-29-2013 08:33 AM in reply to: tonofsteel
If you copy and paste the code into a new VB Class Project and add the following references it should work as advertised, that's how I got the output.
AcCoreMgd
AcDBMgd
AcMgd
NLog
System.Runtime.Serialization
System.ServiceModel
When you say "it doesn't work" please let me know where are you getting stuck?
After compiled this DLL should be netloaded and it should host the WCF service automatically on http://127.0.0.1:7200/ISelectItems endpoint as the logs indicate.
That's my problem, as a newbie I am not very good with the .NET API and there are things I simply couldn't make work with it.  For instance AcadSelectionSet.  If you have some code example showing what you mean I'd appreciate your effort.
My idea of a quick and dirty solution to this problem for now is to just create ACAD commands for what doesn't work directly and send these commands in the service requests instead of trying to make ACAD play nice with WCF because I can still call ActiveDocument.SendCommand() from WCF.
Valued Contributor
tonofsteel
Message 4 of 30 (808 Views)
01-29-2013 08:37 AM in reply to: tonofsteel
How do you load and get this part of the code to run on its own:
Imports NLog
<ServiceContract()>
    Sub SelectItems()
End Interface
        DoSelection()
    End Sub
        Try
                Try
                    Next
                Catch
                End Try
            End Using
        Catch
        End Try
    End Sub
End Class
#End Region
Valued Contributor
sszabo
Message 5 of 30 (803 Views)
01-29-2013 08:53 AM in reply to: tonofsteel
This is just the WCF interface. You have to host it in the clsSelectedItems class by calling the hostService() Sub  and if you do that from Initialize() that will happen automatically when you netload the DLL.  Again, I put all these classes in 1 file intentionally so that people can simply copy/paste into a new class project and should be ready to go.   If that doesn't work for you please tell me what's the error you are getting.
Just a followup on my previous idea: sending the command from the WCF class still gives me this error which is unbelievable because it's executing directly in my IExtensionApplication class and if I invoke the VERY SAME function from the acad command directly it works fine.  This is the strangest thing I've ever seen.
Valued Contributor
sszabo
Message 6 of 30 (795 Views)
01-29-2013 09:21 AM in reply to: sszabo
Here is what I am talking about:
If you add the following helper function to wcfSelectItems, you should be able to invoke any ACAD command from WCF remotely:
    Private ReadOnly Property Acad() As AcadApplication
        Get
            Return DirectCast(Application.AcadApplication, AcadApplication)
        End Get
    End Property
    Public Sub SendCommand(ByVal cmd As String)
            Try
                Dim cmdStr As String = "(command " + Chr(34) + cmd + Chr(34) + " " + ")" + vbCr
                Acad.ActiveDocument.SendCommand(cmdStr)
            Catch
                log.Error("EX 5. {0}", Err.Description)
            End Try
        End Using
    End Sub
And this works with any standard commands such as "RIBBONCLOSE" or "NETLOAD" etc.  However when I call it for the DoSelection command above it gives me the SAME EXACT E_UNEXPECTED error on the SAME EXACT LINE!  Any ideas?!
ps.  To Invoke this from the wcf interface you'll have to also add the following to ISelectItems:
    Sub AcadCmdSelectItems()
and the following to wcfSelectItems:
    Public Sub AcadCmdSelectItems() Implements ISelectItems.AcadCmdSelectItems
        SendCommand("DoSelection")
    End Sub
Valued Contributor
sszabo
Message 7 of 30 (787 Views)
01-29-2013 10:06 AM in reply to: tonofsteel
It just occured to me that this post doesn't contain some basic info on how to test a WCF server out of the box.  After compiling the code above you netload the DLL and then ACAD should be hosting and listening for WCF clients.  To actually invoke DOSELECTION from WCF you can use WCF Test Client that comes with .NET:
http://msdn.microsoft.com/en-us/library/bb552364.aspx
Valued Contributor
tonofsteel
Message 8 of 30 (780 Views)
01-29-2013 10:42 AM in reply to: sszabo
I have not been able to get this code running to reproduce your error.
When I navigate to the page I get the service info.
The logger does not log.
When I try to use WcfTestClient.exe I get exception Object Reference not set to an instance of an object for any URL that I enter.
Valued Contributor
sszabo
Message 9 of 30 (774 Views)
01-29-2013 11:57 AM in reply to: tonofsteel
Ok, I see. I appreciate your effort, if you still have some patience try these tips:
A.The logger does not log.
This is important because this is how you know that your service is hosted correctly in ACAD and what's the exact endpoint it's listening on.  Try the following steps:
1) Install the latest NLog from here: http://nlog-project.org/download
2) Add a New Item to your VB Class Project and select NLog Configuration File.  This will create an NLog.config file with default target going to "${basedir}/log.txt" where ${basedir} is your ACAD directory (For me that's C:\Program Files\Autodesk\AutoCAD 2013).  Copy this config file in your autocad directory. (Alternatively you can specify to Copy Always to your project output directory and set that to ACAD path).  You also have to copy C:\Program Files (x86)\NLog\.NET Framework 4.0\NLog.dll in your ACAD directory (provided you are using NLog 4.0 in your project)
Optionally you can also view your logs in real time as opposed to opening log.text all the time:
http://log2console.codeplex.com/
B) When I try to use WcfTestClient.exe I get exception Object Reference not set to an instance of an object for any URL that I enter.
You can open log.txt in your ACAD directory and copy the exact URL from the first line:
2013-01-29 13:50:36.7247|INFO|clsWcfTestPrj.clsSelectedItems|Listening on http://127.0.0.1:7200/ISelectItems
In WCF test client click File -> Add Service and paste in the blue URL above.  When connected you should be able to see the SelectItems request and you should be able to push the Invoke button.  In the logs you will see the error code.  Then you can go to ACAD command line and type in DOSELECTION and see all the selection objects listed provided you had a drawing open with objects in it.
Hope this will work, let me know if you need any more help.
Valued Contributor
tonofsteel
Message 10 of 30 (772 Views)
01-29-2013 12:00 PM in reply to: sszabo
WcfTestClient.exe will not work on my setup.  It always crashes and never loads up the service.  I got WCFStorm and got the logger going (config file needed to be in autoCAD directory for it to start writing files).
I now have the same error you were getting and it is getting logged.
You are not logged in.
Ask the Community
