Where did the Win32=True come from?
To answer the other question, yes you should use the
assemblies from the SDK, not the ones from the program
folder.
The assemblies for COM interop could be the problem.
Is there a 32 bit version of AutoCAD installed on the same
system?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6355539@discussion.autodesk.com...
In Compile tab I have Platform: Active (any CPU) - the only option available in
combo box.
Advanced Compiler Setting shown on attached image
Alex
