.NET
Active Contributor
Fredrik.Larsen
Message 1 of 7 (310 Views)
Accepted Solution
Cancel change active document
310 Views, 6 Replies
01-24-2013 06:19 AM
Hi
How can I stop changing active document?
I was thinking I could use this, but I don't know how to cancel it in the event handler:
AcadApp.DocumentManager.DocumentToBeActivated += new DocumentCollectionEventHandler(DocumentManager_DocumentToBeActivated);
static void DocumentManager_DocumentToBeActivated(object sender, DocumentCollectionEventArgs e)
    // Messagebox to ask if user are sure
    bool AreYouSureYouWantToChangeActiveFile = MessageBox....
    if(!AreYouSureYouWantToChangeActiveFile)
        //cancel change active file somehow...???
Moderator
Alexander.Rivilis
Message 2 of 7 (297 Views)
Re: Cancel change active document
01-24-2013 01:47 PM in reply to: Fredrik.Larsen
DocumentCollection.DocumentActivationEnabled property can help you
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
Fredrik.Larsen
Message 3 of 7 (283 Views)
01-25-2013 12:06 AM in reply to: Alexander.Rivilis
Hi
I could not get it to work. When I set the property you mentioned the active document has already changed. And if I set the property to false at a earlier stage I will never come to the listener. Any ideas?
            DialogResult dialogResult = MessageBox.Show("You are changing the active drawing. Continue?", "Active drawing change", MessageBoxButtons.YesNo);
            if (dialogResult == DialogResult.Yes)
                AcadApp.DocumentManager.DocumentActivationEnabled = true;
                RemoveDocumentToBeActivatedListener();
            else if (dialogResult == DialogResult.No)
                AcadApp.DocumentManager.DocumentActivationEnabled = false;
Moderator
Alexander.Rivilis
Message 4 of 7 (279 Views)
01-25-2013 01:23 AM in reply to: Fredrik.Larsen
1. You can disable switching of Document's at all if you call:
 but not in handler of event of DocumentToBeActivated.
2. If you have to prevent switching in a handler of event of DocumentToBeActivated you have to:
a) save previous Document and set flag of switching in this handler.
b) in command reactor switch Document back to previous Document and clear flag of switching.
Valued Mentor
DiningPhilosopher
Message 5 of 7 (252 Views)
01-28-2013 01:22 AM in reply to: Fredrik.Larsen
Perhaps you can explain why you want to prevent a document from being activated?
Active Contributor
Fredrik.Larsen
Message 6 of 7 (248 Views)
01-28-2013 01:29 AM in reply to: DiningPhilosopher
I have created an application that scans and does something with the active document and I haven't implemented support for what happens when active document is changed. So for my demo version I thought I could just prevent the user from changing the document.
Moderator
Alexander.Rivilis
Message 7 of 7 (244 Views)
01-28-2013 01:45 AM in reply to: Fredrik.Larsen
While command with CommandFlags.Modal is active user can not switch active document. More precisely when switching to another document, the command will paused and wait for switch back.
You are not logged in.
Announcements
Need installation help?
Ask the Community
