• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    Cancel change active document
    168 Views, 6 Replies
    01-24-2013 06:19 AM
    Hi
    How can I stop changing active document?
    I was thinking I could use this, but I don't know how to cancel it in the event handler:
    AcadApp.DocumentManager.DocumentToBeActivated += new DocumentCollectionEventHandler(DocumentManager_DocumentToBeActivated);
    static void DocumentManager_DocumentToBeActivated(object sender, DocumentCollectionEventArgs e)
        // Messagebox to ask if user are sure
        bool AreYouSureYouWantToChangeActiveFile = MessageBox....
        if(!AreYouSureYouWantToChangeActiveFile)
            //cancel change active file somehow...???
    Please use plain text.
    Moderator
    Alexander.Rivilis
    Re: Cancel change active document
    01-24-2013 01:47 PM in reply to: Fredrik.Larsen
    DocumentCollection.DocumentActivationEnabled property can help you
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Active Contributor
    01-25-2013 12:06 AM in reply to: Alexander.Rivilis
    Hi
    I could not get it to work. When I set the property you mentioned the active document has already changed. And if I set the property to false at a earlier stage I will never come to the listener. Any ideas?
                DialogResult dialogResult = MessageBox.Show("You are changing the active drawing. Continue?", "Active drawing change", MessageBoxButtons.YesNo);
                if (dialogResult == DialogResult.Yes)
                    AcadApp.DocumentManager.DocumentActivationEnabled = true;
                    RemoveDocumentToBeActivatedListener();
                else if (dialogResult == DialogResult.No)
                    AcadApp.DocumentManager.DocumentActivationEnabled = false;
    Moderator
    Alexander.Rivilis
    01-25-2013 01:23 AM in reply to: Fredrik.Larsen
    1. You can disable switching of Document's at all if you call:
     but not in handler of event of DocumentToBeActivated.
    2. If you have to prevent switching in a handler of event of DocumentToBeActivated you have to:
    a) save previous Document and set flag of switching in this handler.
    b) in command reactor switch Document back to previous Document and clear flag of switching.
    Valued Mentor
    01-28-2013 01:22 AM in reply to: Fredrik.Larsen
    Perhaps you can explain why you want to prevent a document from being activated?
    Active Contributor
    01-28-2013 01:29 AM in reply to: DiningPhilosopher
    I have created an application that scans and does something with the active document and I haven't implemented support for what happens when active document is changed. So for my demo version I thought I could just prevent the user from changing the document.
    Moderator
    Alexander.Rivilis
    01-28-2013 01:45 AM in reply to: Fredrik.Larsen
    While command with CommandFlags.Modal is active user can not switch active document. More precisely when switching to another document, the command will paused and wait for switch back.
