.NET
Valued Contributor
michael.vanhoose
Message 1 of 3 (159 Views)
Can you do a selection set based on Extended Dictionary on a Entity?
159 Views, 2 Replies
01-16-2013 07:46 AM
'' Get the current document editor
Dim acDocEd AsEditor = Application.DocumentManager.MdiActiveDocument.Editor
'' Create a TypedValue array to define the filter criteriaDim acTypValAr(0) AsTypedValue
acTypValAr.SetValue(
NewTypedValue(DxfCode.?????????, _
"???"), 0)
'' Assign the filter criteria to a SelectionFilter objectDim acSelFtr As SelectionFilter = NewSelectionFilter(acTypValAr)
'' Request for objects to be selected in the drawing areaDim acSSPrompt AsPromptSelectionResult
acSSPrompt = acDocEd.GetSelection(acSelFtr)
'' If the prompt status is OK, objects were selectedIf acSSPrompt.Status = PromptStatus.OK ThenDim acSSet AsSelectionSet = acSSPrompt.Value
Application.ShowAlertDialog(
"Number of objects selected: "& _
acSSet.Count.ToString())
Else
"Number of objects selected: 0")
EndIf
Moderator
Alexander.Rivilis
Message 2 of 3 (152 Views)
Re: Can you do a selection set based on Extended Dictionary on a Entity?
01-16-2013 09:03 AM in reply to: michael.vanhoose
No. There is no criteria to filter selection set with Extension Dictionary.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
michael.vanhoose
Message 3 of 3 (137 Views)
01-16-2013 11:14 AM in reply to: Alexander.Rivilis
Thanks for the reply
You are not logged in.
Ask the Community
