.NET
New Member
NamelessDN
Message 1 of 6 (650 Views)
Can't use function GetBoundingBox from C# application
650 Views, 5 Replies
01-29-2010 06:22 AM
Hi.
I work with Autocad from C# application using late binding.
After inserting block, i want to get its bounds.
double[] aMinPoint = new double[3], aMaxPoint = new double[3];
Params = new object[] { aMinPoint, aMaxPoint };
oBlock.GetType().InvokeMember("GetBoundingBox", BindingFlags.InvokeMethod, null, oBlock, Params);
But after execution this code aMaxPoint and aMinPoint had their default values - 0.
What do I do wrong?
By the way the same task in VB.NET (with built-in late binding) solves good.
Dim aMinPoint() As Double
Dim aMaxPoint() As Double
oBlock.GetBoundingBox(aMinPoint, aMaxPoint)
Thanks for help.
*Tony Tanzillo
Message 2 of 6 (650 Views)
Re: Can't use function GetBoundingBox from C# application
01-29-2010 10:51 PM in reply to: NamelessDN
See the sample code here:
http://www.caddzone.com/LateBoundComSample.cs
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6326932@discussion.autodesk.com...
Hi.
oBlock, Params);
0.
What do I do wrong?
Thanks for help.
New Member
NamelessDN
Message 3 of 6 (650 Views)
01-29-2010 11:34 PM in reply to: NamelessDN
Perfect sample, thanks.
amitk_189
Message 4 of 6 (359 Views)
07-26-2012 03:19 AM in reply to: NamelessDN
Can you share a copy of part of code because am unable to find data in the link. Am also using the same concept of GetBoundingBox to Get the location of Texts.
ADN Support Specialist
Virupaksha.aithal
Message 5 of 6 (322 Views)
07-31-2012 02:16 AM in reply to: amitk_189
Hi
refer blog post http://adndevblog.typepad.com/autocad/2012/07/using-activex-api-getboundingbox-in-net.html. The post shows the use of GetBoundingBox in c#  application
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
amitk_189
Message 6 of 6 (316 Views)
07-31-2012 03:06 AM in reply to: NamelessDN
Hello Virupaksha.aithal, i resolved this issue quite some time ago, but stuck up in a new location. Call rejected by callee.
I have already posted a issue in the forum and side by side i am also trying to execute this, but my code gets stuck at Call rejected by callee.
Then if i press F5 it works as expected
http://forums.autodesk.com/t5/NET/Call-Rejected-by-Callee/td-p/3558826
This is the link for it
With Warm Regards
Amit
You are not logged in.
Ask the Community
