Hello Forum,
after I redefine a block (I make it bigger), I can't select the block by clicking on the part that's gotten bigger. It is as if AutoCAD still remembers the outlining of the previous smaller block and if I click outside this outlining it doesnt select the block. If I save, close and reopen the drawing everything is fine and I can select the block as normal.
Why is this caused?
Thank you.
// Insert from dwg file. using (dbInsert = new Database(false, true)) { dbInsert.ReadDwgFile(strDwgPath, System.IO.FileShare.Read, true, ""); oidInsert = dbActive.Insert(System.IO.Path.GetFileNameWithoutExtension(strDwgPath), dbInsert, true); }
// Regenerate the drawing CADS.Application.DocumentManager.MdiActiveDocument.Editor.Regen();
Solved by arcticad. Go to Solution.
... insert random untested code here ....
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim db As Database = doc.Database
Using tr As Transaction = db.TransactionManager.StartTransaction()
Dim bref As BlockReference = Nothing
.. do stuff
bref.RecordGraphicsModified(True)
tr.TransactionManager.QueueForGraphicsFlush()
doc.TransactionManager.FlushGraphics()
ed.UpdateScreen()
tr.Commit()
