Message 1 of 11
08:13 AM
I've been trying to find helpful documentation to start writing applications for my CAD team, but with the move to Cad 2011, Windows 7 64Bit, ect...there's nothing I can find that will show me even basic stuff like attaching to AutoCAD and grabbing the area of all entities. Here's what I have writen down. I know it doesn't work, because it comes up with an error message and crashed before it gets into the Sub.
Option Explicit On
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports System.Text
Imports System
Public Class Form1
Friend Sub DoStuff() Handles Button1.Click
MsgBox("Neat")
' Get active AutoCAD Application
Dim app As Application = GetObject(, "AutoCAD.Application")
' Get active document
Dim doc As Document = app.DocumentManager.MdiActiveDocument
' Create the database object
Dim dwg As Database = doc.Editor.Document.Database
' Populate the selection set with objects that match the filter criteria
Dim sel As SelectionSet = doc.Editor.SelectAll().Value
' Start a transaction
Dim trans As Transaction = dwg.TransactionManager.StartTransaction
' Loop through each selected object in the selection set
Dim entSet As New DBObjectCollection
Try
For Each selEnt As SelectedObject In sel
Dim ent As Entity = trans.GetObject(selEnt.ObjectId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
Dim entType As String = ent.GetType.ToString
Dim entArea
Select Case ent.GetType.ToString
Case "Autodesk.AutoCad.DatabaseServices.DBArc"
Dim arcEnt As Arc = ent
entArea = arcEnt.Area
Case "Autodesk.AutoCad.DatabaseServices.DBCircle"
Dim cirEnt As Circle = ent
entArea = cirEnt.Area
Case "Autodesk.AutoCad.DatabaseServices.DBEllipse"
Dim eliEnt As Ellipse = ent
entArea = eliEnt.Area
Case "Autodesk.AutoCad.DatabaseServices.DBPolyline"
Dim plyEnt As Polyline = ent
entArea = plyEnt.Area
Case "Autodesk.AutoCad.DatabaseServices.DBRegion"
Dim regEnt As Region = ent
entArea = regEnt.Area
Case "Autodesk.AutoCad.DatabaseServices.DBSpline"
Dim splEnt As Spline = ent
entArea = splEnt.Area
Case Else
End Select
Next
Catch ex As Autodesk.AutoCAD.Runtime.Exception
End Try
End Sub
End Class
It's simple. All I want to do is go to each entitiy in the drawing and find their area. I plan on combining the areas to show total area. But the program crashes before I can even get it to work. I have two warnings right now displaying, so those may be it.
Warning 1 Possible problem detected while building assembly 'TestTestTestTest': Referenced assembly 'mscorlib.dll' targets a different processor TestTestTestTest Warning 2 Access of shared member, constant member, enum member or nested type through an instance; qualifying expression will not be evaluated. U:\settings\My Documents\Visual Studio 2010\Projects\TestTestTestTest\TestTestTestTest\Form1.vb 21 31 TestTestTestTest
