• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    New Member
    truss85
    Can not write selected block attributes
    199 Views, 5 Replies
    01-15-2012 01:27 PM
    Hi Everybody,
    I have a prblem with the code. I posted the code below. I have two questions about the code.
    The First in vba there is a function refers to blocks effective name is there ant similar function vb.net has?
    Because when I filtered  Blocks that I want particularly DYNBlocks I get all of them in vba I inserted
    İf blockobject.effectivename=" ..." then
    it can solved. but invb.net I did not find a way to get rid of this...
    The second question is the code can not able to write attribute when selecting fence mode. In normal selection it did not happen. What am I doing wrong?
    Thanks for replies...
    Imports Autodesk.AutoCAD.ApplicationServices
    Imports Autodesk.AutoCAD.DatabaseServices
    Imports Autodesk.AutoCAD.EditorInput
    Imports Autodesk.AutoCAD.Geometry
    Imports Autodesk.AutoCAD.Runtime
    Public Class Class1
        <CommandMethod("gss")> _
        Public Sub gget()
            Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            Dim entOpt As PromptEntityOptions = New PromptEntityOptions("select a polyline:")
            entOpt.AllowNone = True
            Dim spoly As PromptEntityResult = acDocEd.GetEntity(entOpt)
            Dim acCurDb As Database = Application.DocumentManager.MdiActiveDocument.Database
            Using acTrans1 As Transaction = acCurDb.TransactionManager.StartTransaction()
                Dim obj As DBObject = acTrans1.GetObject(spoly.ObjectId, OpenMode.ForWrite)
                If TypeOf (obj) Is Polyline Then
                    Dim poly As Polyline = CType(obj, Polyline)
                    Dim opt As New Point3d
                    Dim sel_fence As New Autodesk.AutoCAD.Geometry.Point3dCollection
                    For ii = 0 To poly.NumberOfVertices - 1
                        opt = poly.GetPoint3dAt(ii)
                        sel_fence.Add(opt)
                    Next
                    Dim acTypValAr(0) As TypedValue
                    acTypValAr(0) = New TypedValue(Autodesk.AutoCAD.DatabaseServices.DxfCode.BlockName, "MET-HVZ2,`*U*")
                    Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
                    Dim sblck As PromptSelectionResult = acDocEd.SelectFence(sel_fence, acSelFtr)
                    If sblck.Status = PromptStatus.OK Then
                        Dim acSSet As SelectionSet = sblck.Value
                        Dim nnstr As String
                        Dim nn As Integer
                        nn = 1
                        For Each acSSObj As SelectedObject In acSSet
                            Dim acEnt As Entity = acTrans1.GetObject(acSSObj.ObjectId, OpenMode.ForWrite)
                            nnstr = "H" & nn.ToString
                            SetAttribute(acSSObj.ObjectId, "HIDRANT_ISIM", nnstr)
                            nn = nn + 1
                        Next
                        acDocEd.WriteMessage("Number of objects selected: " & acSSet.Count.ToString())
                    Else
                        acDocEd.WriteMessage("Number of objects selected: 0")
                Else
                    acDocEd.WriteMessage("Selection must be a polyline...")
            End Using
        End Sub
    Please use plain text.
    Active Contributor
    cincir
    Re: Can not write selected block attributes
    01-15-2012 08:10 PM in reply to: truss85
    all the block objects are BlockReference objects those reference to a BlockTableRecord objects in BlockTable. BlockReference objects have IsDynamicBlock , DynamicBlockTableRecord and BlockTableRecord properties. you can check if a BlockReference is pointing to a DynamicBlock or not via IsDynamicBlock property. this property returns true or false. after you determine the type you can obtain ObjectId of the BlockTableRecord via DynamicBlockTableRecord or BlockTableRecord. and if you open BlockTableRecord you can obtain its name via its Name property. Also the Name property of BlockReference object returns the name of the BlockTableRecord it references to.
    Hope that helps.
    Distinguished Contributor
    truss_85
    01-16-2012 04:16 AM in reply to: cincir
    Firdt of all thanks for the answer;
    But it is not a solution. Let say I have two different dynamic block in the selection set both name return to "`*U*".
    You Know that a dynamic block if it is dynamic properties not set default block.name property returns "`*U*" also
    IsDynamicBlock property returns block is dynamic or can not give a clue about block name always returns "`*U*".
    If you take a look to selection filter, you had seen I filtered all the dynamic blocks already.
    I want effective name to get rid of that or any other way excepted. I hope I represent my problem clearly.
    01-16-2012 06:20 AM in reply to: truss85
    If you want to filter dynamic blocks, i think it's better to select just generic "INSERT" and then to check if is dynamic and it have the name you want , like this:
    Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                acTypValAr.SetValue(New TypedValue(DxfCode.Start, "INSERT"), 0)
                Dim acSSPrompt As PromptSelectionResult
                acSSPrompt = ed.SelectAll(acSelFtr)
                If acSSPrompt.Status = PromptStatus.OK Then
                    Dim acSSet As SelectionSet = acSSPrompt.Value
                        Dim blkref As BlockReference = acSSObj.ObjectId.GetObject(OpenMode.ForRead)
                        If blkref.IsDynamicBlock Then
                        Dim btr As BlockTableRecord
                        btr = acTrans.GetObject(blkref.DynamicBlockTableRecord, OpenMode.ForRead)
                        If btr.Name="MyBlockName" then
                     Next
    End Using
    Hope this help you.
    Gaston Nunez
    truss_85
    01-16-2012 10:34 AM in reply to: gasty1001
    Thanks gusty1001 it worked.
    I also ove an appology to cincer I can not understand
    what you are saying...
    Anyway thanks to both of you...
    Active Contributor
    cincir
    01-16-2012 01:53 PM in reply to: truss_85
    No appologies needed. happy that helps solve your problem. maybe it was better to show code .
