.NET
New Member
truss85
Message 1 of 6 (260 Views)
Can not write selected block attributes
260 Views, 5 Replies
01-15-2012 01:27 PM
Hi Everybody,
I have a prblem with the code. I posted the code below. I have two questions about the code.
The First in vba there is a function refers to blocks effective name is there ant similar function vb.net has?
Because when I filtered  Blocks that I want particularly DYNBlocks I get all of them in vba I inserted
İf blockobject.effectivename=" ..." then
it can solved. but invb.net I did not find a way to get rid of this...
The second question is the code can not able to write attribute when selecting fence mode. In normal selection it did not happen. What am I doing wrong?
Thanks for replies...
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Runtime
Public Class Class1
    <CommandMethod("gss")> _
    Public Sub gget()
        Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim entOpt As PromptEntityOptions = New PromptEntityOptions("select a polyline:")
        entOpt.AllowNone = True
        Dim spoly As PromptEntityResult = acDocEd.GetEntity(entOpt)
        Dim acCurDb As Database = Application.DocumentManager.MdiActiveDocument.Database
        Using acTrans1 As Transaction = acCurDb.TransactionManager.StartTransaction()
            Dim obj As DBObject = acTrans1.GetObject(spoly.ObjectId, OpenMode.ForWrite)
            If TypeOf (obj) Is Polyline Then
                Dim poly As Polyline = CType(obj, Polyline)
                Dim opt As New Point3d
                Dim sel_fence As New Autodesk.AutoCAD.Geometry.Point3dCollection
                For ii = 0 To poly.NumberOfVertices - 1
                    opt = poly.GetPoint3dAt(ii)
                    sel_fence.Add(opt)
                Next
                Dim acTypValAr(0) As TypedValue
                acTypValAr(0) = New TypedValue(Autodesk.AutoCAD.DatabaseServices.DxfCode.BlockName, "MET-HVZ2,`*U*")
                Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
                Dim sblck As PromptSelectionResult = acDocEd.SelectFence(sel_fence, acSelFtr)
                If sblck.Status = PromptStatus.OK Then
                    Dim acSSet As SelectionSet = sblck.Value
                    Dim nnstr As String
                    Dim nn As Integer
                    nn = 1
                    For Each acSSObj As SelectedObject In acSSet
                        Dim acEnt As Entity = acTrans1.GetObject(acSSObj.ObjectId, OpenMode.ForWrite)
                        nnstr = "H" & nn.ToString
                        SetAttribute(acSSObj.ObjectId, "HIDRANT_ISIM", nnstr)
                        nn = nn + 1
                    Next
                    acDocEd.WriteMessage("Number of objects selected: " & acSSet.Count.ToString())
                Else
                    acDocEd.WriteMessage("Number of objects selected: 0")
                End If
            Else
                acDocEd.WriteMessage("Selection must be a polyline...")
            End If
        End Using
    End Sub
Active Contributor
cincir
Message 2 of 6 (249 Views)
Re: Can not write selected block attributes
01-15-2012 08:10 PM in reply to: truss85
all the block objects are BlockReference objects those reference to a BlockTableRecord objects in BlockTable. BlockReference objects have IsDynamicBlock , DynamicBlockTableRecord and BlockTableRecord properties. you can check if a BlockReference is pointing to a DynamicBlock or not via IsDynamicBlock property. this property returns true or false. after you determine the type you can obtain ObjectId of the BlockTableRecord via DynamicBlockTableRecord or BlockTableRecord. and if you open BlockTableRecord you can obtain its name via its Name property. Also the Name property of BlockReference object returns the name of the BlockTableRecord it references to.
Hope that helps.
truss_85
Message 3 of 6 (236 Views)
01-16-2012 04:16 AM in reply to: cincir
Firdt of all thanks for the answer;
But it is not a solution. Let say I have two different dynamic block in the selection set both name return to "`*U*".
You Know that a dynamic block if it is dynamic properties not set default block.name property returns "`*U*" also
IsDynamicBlock property returns block is dynamic or can not give a clue about block name always returns "`*U*".
If you take a look to selection filter, you had seen I filtered all the dynamic blocks already.
I want effective name to get rid of that or any other way excepted. I hope I represent my problem clearly.
Valued Mentor
gasty1001
Message 4 of 6 (225 Views)
01-16-2012 06:20 AM in reply to: truss85
If you want to filter dynamic blocks, i think it's better to select just generic "INSERT" and then to check if is dynamic and it have the name you want , like this:
Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            acTypValAr.SetValue(New TypedValue(DxfCode.Start, "INSERT"), 0)
            Dim acSSPrompt As PromptSelectionResult
            acSSPrompt = ed.SelectAll(acSelFtr)
            If acSSPrompt.Status = PromptStatus.OK Then
                Dim acSSet As SelectionSet = acSSPrompt.Value
                    Dim blkref As BlockReference = acSSObj.ObjectId.GetObject(OpenMode.ForRead)
                    If blkref.IsDynamicBlock Then
                    Dim btr As BlockTableRecord
                    btr = acTrans.GetObject(blkref.DynamicBlockTableRecord, OpenMode.ForRead)
                    If btr.Name="MyBlockName" then
                    End If
                 Next
              End If
End Using
Hope this help you.
Gaston Nunez
truss_85
Message 5 of 6 (208 Views)
01-16-2012 10:34 AM in reply to: gasty1001
Thanks gusty1001 it worked.
I also ove an appology to cincer I can not understand
what you are saying...
Anyway thanks to both of you...
Active Contributor
cincir
Message 6 of 6 (198 Views)
01-16-2012 01:53 PM in reply to: truss_85
No appologies needed. happy that helps solve your problem. maybe it was better to show code .
You are not logged in.
Ask the Community
