.NET
truss_85
Message 11 of 16 (180 Views)
Re: Can not snap locked layers
05-14-2012 02:10 AM in reply to: Hallex
No Problem
I think I did not express my self clearly.
Thanks again
Distinguished Mentor
BlackBox_
Message 12 of 16 (83 Views)
Re : Can not snap locked layers
03-25-2014 07:47 AM in reply to: _gile
_gile wrote:
... I didn't find no way to get it work with the INTersect osnap.
I've just stumbled across this thread, and your post looks to be very useful, Gile - Thank you.
As I am just starting to researching this topic, and you may already be aware, Kean shows how to deal with INTersect osnap using GeometryOverrule here:
http://through-the-interface.typepad.com/through_the_interface/2013/12/disabling-snapping-to-specifi...
Cheers
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
_gile
Message 13 of 16 (79 Views)
03-25-2014 08:24 AM in reply to: BlackBox_
Thanks BlackBox_.
I saw Kean's thread sometimes ago. I rewrote the code to publish it on a French web site: CADxp.
Two toggle commands are defined. Both can be called transparently.
LOKO to (de)activate osnaps on locked layers.
XROS to (de)activate osnaps on xrefs.
Here's the code:
using System;
using System.Collections.Generic;
using System.Linq;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(Gile.LockOsnap.CommandMethods))]
namespace Gile.LockOsnap
    public class CommandMethods
        private OSOverrule lokoOSOverrule, xrosOSOverrule;
        private IntOverrule lokoIntOverrule, xrosIntOverrule;
        [CommandMethod("LOKO", CommandFlags.Modal | CommandFlags.Transparent)]
        public void LockOsnapCmd()
            ToggleOsnaps(ref lokoOSOverrule, ref lokoIntOverrule, lokoPromptingForPoint, LockedUpdate, "calques verrouillés");
        [CommandMethod("XROS", CommandFlags.Modal | CommandFlags.Transparent)]
        public void XrefOsnapCmd()
            ToggleOsnaps(ref xrosOSOverrule, ref xrosIntOverrule, xrosPromptingForPoint, XrefUpdate, "références externes");
        void lokoPromptingForPoint(object sender, PromptPointOptionsEventArgs e)
            LockedUpdate();
        void xrosPromptingForPoint(object sender, PromptPointOptionsEventArgs e)
            XrefUpdate();
        private void ToggleOsnaps(
            ref OSOverrule osOverrule,
            ref IntOverrule intOverrule,
            PromptPointOptionsEventHandler handler,
            Action update,
            string msg)
            Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
            RXClass entityClass = RXClass.GetClass(typeof(Entity));
            if (osOverrule == null)
                ed.PromptingForPoint += handler;
                osOverrule = new OSOverrule();
                Overrule.AddOverrule(entityClass, osOverrule, false);
                intOverrule = new IntOverrule();
                Overrule.AddOverrule(entityClass, intOverrule, false);
                ed.WriteMessage(string.Format("\nAccrochages sur les {0} désactivés.", msg));
                update();
                Overrule.Overruling = true;
            else
                ed.PromptingForPoint -= xrosPromptingForPoint;
                Overrule.RemoveOverrule(entityClass, osOverrule);
                osOverrule = null;
                Overrule.RemoveOverrule(entityClass, intOverrule);
                intOverrule = null;
                ed.WriteMessage(string.Format("\nAccrochages sur les {0} activés.", msg));
        private void LockedUpdate()
            if (lokoOSOverrule != null)
                Database db = HostApplicationServices.WorkingDatabase;
                using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
                    HashSet<string> layers = new HashSet<string>(
                        ((LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead))
                        .Cast<ObjectId>()
                        .Select(id => (LayerTableRecord)tr.GetObject(id, OpenMode.ForRead))
                        .Where(ltr => ltr.IsLocked)
                        .Select(ltr => ltr.Name));
                    ObjectId[] onLocked = ((BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead))
                        .Cast<ObjectId>()
                        .Where(id => layers.Contains(((Entity)tr.GetObject(id, OpenMode.ForRead)).Layer))
                        .ToArray();
                    lokoOSOverrule.SetIdFilter(onLocked);
                    lokoIntOverrule.SetIdFilter(onLocked);
                    tr.Commit();
        private void XrefUpdate()
            if (xrosOSOverrule != null)
                    ObjectId[] xrIds = ((BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead))
                        .Cast<ObjectId>()
                        .Select(id => (BlockTableRecord)tr.GetObject(id, OpenMode.ForRead))
                        .Where(btr => btr.IsFromExternalReference)
                        .SelectMany(btr => btr.GetBlockReferenceIds(true, false).Cast<ObjectId>())
                        .ToArray();
                    xrosOSOverrule.SetIdFilter(xrIds);
                    xrosIntOverrule.SetIdFilter(xrIds);
                    tr.Commit();
        class OSOverrule : OsnapOverrule
            public override void GetObjectSnapPoints(
              Entity ent,
              ObjectSnapModes mode,
              IntPtr gsm,
              Point3d pick,
              Point3d last,
              Matrix3d view,
              Point3dCollection snap,
              IntegerCollection geomIds) { }
              Entity ent,
              IntPtr gsm,
              Point3d pick,
              Point3d last,
              Matrix3d view,
              Point3dCollection snaps,
              IntegerCollection geomIds,
              Matrix3d insertion) { }
            public override bool IsContentSnappable(Entity entity)
                return false;
        class IntOverrule : GeometryOverrule
            public override void IntersectWith(
              Entity ent1,
              Entity ent2,
              Intersect intType,
              Plane proj,
              Point3dCollection points,
              IntPtr thisGsm,
              IntPtr otherGsm) { }
              Entity ent1,
              Entity ent2,
              Intersect intType,
              IntPtr thisGsm,
Gilles Chanteau
BlackBox_
Message 14 of 16 (73 Views)
03-25-2014 09:35 AM in reply to: _gile
_gile wrote:
Thanks BlackBox_.
I suspected you would have, as I know you to be well informed, but had to take the chance at being of some small amount of help to one who has been so helpful to me in the past.
While I have not yet tested for myself, your description, and a quick glance at the code leaves me with only one thought... Simply brilliant.
Separately, I often come across your posts when trying to accomplish a task, or learn how to go about something. Do you by chance have a website, etc. that I might be able to read tips & tutorials on the myriad facets of the AutoCAD .NET API?
Cheers
_gile
Message 15 of 16 (69 Views)
03-25-2014 09:57 AM in reply to: BlackBox_
I have a (very) little web site (gilecAD) but there're not so much tutos and all in French.
Gilles Chanteau
BlackBox_
Message 16 of 16 (65 Views)
03-25-2014 10:17 AM in reply to: _gile
You have more content on your site than I do; thanks for sharing. :thumbsup:
You are not logged in.
Ask the Community
