.NET
Can not ref acmgd.dll or acdbmgd.dll.
3 REPLIES 3
NathTay
397 Views, 3 Replies
I have already posted this in the Map Developer group here http://discussion.autodesk.com/thread.jspa?threadID=476093. As it may not be specific I am reposting here hoping the cross post gestapo are not watching.
Using Visual Studio 2003 & Map 3D 2007 I can not add references to acmgd.dll or acdbmgd.dll. I recieve the message shown in the attached image.
Has any one had the same problem or successfully added the references.
I am using the same process as with VS03 & Map05 which works.
Regards - Nathan
3 REPLIES 3
in reply to: NathTay
You need VS 2005.
Best Regards, Jimmy Bergmark
CAD and Database Developer Manager at www.pharmadule-emtunga.com
Blog: http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm report tool) -
http://www.jtbworld.com/jtbflexreport
SmartPurger (Purges automatically) - http://www.jtbworld.com/smartpurger.htm
or download some freeware at http://www.jtbworld.com
More on AutoCAD 2006 and 2007
http://www.jtbworld.com/autocad2006.htm
http://www.jtbworld.com/autocad2007.htm
wrote in message news:5191584@discussion.autodesk.com...
Regards - Nathan
I think you need .NET 2.0 and VS2005.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
Regards - Nathan
NathTay
Thanks Tony, Jimmy and Norman (in map group) you confirmed my suspicions. The ObjectARX docs are not to clear on it. I will try an Express edition before getting the commitment to upgrade.
Regards - Nathan
”Boost
