• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Distinguished Contributor
    truss_85
    Can not operate items in selection set
    130 Views, 2 Replies
    02-26-2012 07:19 AM
    Hi Everyone,
    I have a public sub it works fine with selectionsets.
    But when I want to use in a fence selection set it did not work.
    I get message "number of selected object:" truly but it did not set att values.
    I post the code below. What am I missing?
    Imports Autodesk.AutoCAD.ApplicationServices
    Imports Autodesk.AutoCAD.DatabaseServices
    Imports Autodesk.AutoCAD.EditorInput
    Imports Autodesk.AutoCAD.Geometry
    Imports Autodesk.AutoCAD.Runtime
    Public Class Class1
        <CommandMethod("hs")> _
        Public Sub gget()
            Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            Dim entOpt As PromptEntityOptions = New PromptEntityOptions("Pick a polyline:")
            entOpt.AllowNone = True
            Dim spoly As PromptEntityResult = acDocEd.GetEntity(entOpt)
            Dim acCurDb As Database = Application.DocumentManager.MdiActiveDocument.Database
            If spoly.Status = PromptStatus.None Then
                acDocEd.WriteMessage("Selection invalid!...")
            End If
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                Dim obj As DBObject = acTrans.GetObject(spoly.ObjectId, OpenMode.ForWrite)
                If TypeOf (obj) Is Polyline Then
                    Dim poly As Polyline = CType(obj, Polyline)
                    Dim opt As New Point3d
                    Dim sel_fence As New Autodesk.AutoCAD.Geometry.Point3dCollection
                    For ii = 0 To poly.NumberOfVertices - 1
                        opt = poly.GetPoint3dAt(ii)
                        sel_fence.Add(opt)
                    Next
                    Dim acTypValAr(0) As TypedValue
                    acTypValAr.SetValue(New TypedValue(DxfCode.Start, "INSERT"), 0)
                    Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
                    Dim prselres As PromptSelectionResult = acDocEd.SelectFence(sel_fence, acSelFtr)
                    If prselres.Status = PromptStatus.OK Then
                        Dim acSSet As SelectionSet = prselres.Value
                        Dim nn As Integer = 0
                        For Each acSSObj As SelectedObject In acSSet
                            SetAttribute(acSSObj.ObjectId, "BLOCKNAME", "ATTNAME", nn.ToString)
                            nn = nn + 1
                        Next
                        acDocEd.WriteMessage("Number of objects selected: " & acSSet.Count.ToString())
                    End If
                End If
            End Using
        End Sub
        Public Sub SetAttribute(ByVal BlockID As Autodesk.AutoCAD.DatabaseServices.ObjectId, ByVal blckname As String, ByVal AttTag As String, ByVal AttVal As String)
            Dim MyDb As Database = Application.DocumentManager.MdiActiveDocument.Database
            If BlockID.IsNull Then Exit Sub
            Try
                Using myTrans As Transaction = MyDb.TransactionManager.StartTransaction
                    Dim myBlckRef As BlockReference
                    Dim myAttColl As AttributeCollection
                    Dim myBlckTable As BlockTableRecord
                    myBlckRef = BlockID.GetObject(OpenMode.ForWrite)
                    If myBlckRef.IsDynamicBlock Then
                        myBlckTable = myTrans.GetObject(myBlckRef.DynamicBlockTableRecord, OpenMode.ForRead)
                    Else
                        myBlckTable = myTrans.GetObject(myBlckRef.BlockTableRecord, OpenMode.ForRead)
                    End If
                    If String.Compare(myBlckTable.Name, blckname, True) = 0 Then
                        myAttColl = myBlckRef.AttributeCollection
                        Dim myEnt As Autodesk.AutoCAD.DatabaseServices.ObjectId
                        Dim myAttRef As Autodesk.AutoCAD.DatabaseServices.AttributeReference
                        For Each myEnt In myAttColl
                            myAttRef = myEnt.GetObject(OpenMode.ForWrite)
                            If String.Compare(myAttRef.Tag, AttTag, True) = 0 Then
                                myAttRef.TextString = AttVal.ToString
                            End If
                        Next
                    End If
                    myTrans.Commit()
                End Using
            Catch ex As Exception
            End Try
        End Sub
    End Class
    Please use plain text.
    Re: Can not operate items in selection set
    02-26-2012 07:22 AM in reply to: truss_85
    you are working with nested transactions, that is a little bit more critical and you have to be careful commiting a sub-transaction, but not commiting the top-transaction.
    As a first try do also a commit of the transaction in your primary sub "ssget"
    HTH, - alfred -
    Alfred NESWADBA
    truss_85
    02-26-2012 07:41 AM in reply to: alfred.neswadba
    How embarrassing it is!...
    I did not see that thank you very musch again...
