.NET
Can not create ConnectionIdentifier.Oracle from a windows service
1 REPLY 1
milos.stojic
375 Views, 1 Reply
I have a  windows service that works fine referencing Map 2010's dlls
I need to upgrade the service to Map 3D 2012
I am using only Topobase.Data in references
Basically the problem is in creating SySConnection
This is code from service for 2010 version :
  TopobaseAPI.Data.Sys.SysConnection sysConnection = new TopobaseAPI.Data.Sys.SysConnection(sysusr, syspwd, dataSource, false);
  sysConnection.Open();
but constructor for SysConnection, that is used here, is obsolete in 2012 and error says that I should use ConnectionIdentifier class
So I changed code  to this:
 ConnectionIdentifier.Oracle sysIdentifier = ConnectionIdentifier.Create<ConnectionIdentifier.Oracle>();
 sysIdentifier.UserName = sysUser;
 sysIdentifier.Password = sysPassword;
 sysIdentifier.ServiceName = dataSource;
 Topobase.Data.Sys.SysConnection sysConn = new Topobase.Data.Sys.SysConnection(sysIdentifier);
 sysConn.Open();
but now the first line of code ( ConnectionIdentifier.Oracle sysIdentifier = ConnectionIdentifier.Create<ConnectionIdentifier.Oracle>();) creates this error
Specified argument was out of the range of valid values.
Parameter name: T
This is the list of dlls thet service is using in it's bin folder. They were automatiaclly copied from \AutoCAD Map 3D 2012\bin folder during building.
Antlr3.Runtime.dll
Autodesk.CER.XMLStack.dll
log4net.dll
Topobase.CER.dll
Topobase.Collections.dll
Topobase.Config.dll
Topobase.Data.dll
Topobase.Exception.dll
Topobase.ExceptionDialog.dll
Topobase.Genuine.dll
Topobase.Graphic.dll
Topobase.Graphic.XmlSerializers.dll
Topobase.Math.dll
Topobase.PlaneGeometry.dll
Topobase.Services.dll
Topobase.SpaceGeometry.dll
Topobase.TbpReader.dll
Topobase.Tools.dll
Topobase.Tracing.dll
1 REPLY 1
nallanp
in reply to: milos.stojic
Hi Milos
Did you get a solution for this? I am also trying to migrate code from Topobase 2011 to Map3D 2015, which has a windows service and I am getting the same exact error. Could you resolve this?
”Boost
