.NET
Can not compile successfully
5 REPLIES 5
724 Views, 5 Replies
I am trying to compile in VS 2005 using the "Register for COM Interop" option on the compile tab and the "Make Assembly Com Visible" on the Application Assembly information.
A compile error happens when using the following initialization directive (I have ommited the closing characters of the directive, since they do not display in the forum)
Assembly: ExtensionApplication(GetType(mynamespace.Initialization))
I get the following error
Cannot register assembly "C:..myapps.dll". The specified module could not be found. (Exception from HRESULT: 0x8007007E)
Any help I wil really appreciate
5 REPLIES 5
Your post and your code does not make it clear what
language you're using. I don't know about VB, but in
C#, "GetType()" is a method, which cannot be used in
an attribute constructor.
In C#, you use typeof(ClassName) to specify a
type in an attribute.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5344909@discussion.autodesk.com...
Hi Tony
I am using VB, but I assume it will be the same for C#. In C# it will be something like.
[assembly: ExtensionApplication(typeof(InitClass))]
The rest is according to the vbnet labs, Have you try to compile with the "Register for COM Interop" and "Make Assembly Com Visible" options in VS 2005?. If I uncheck them it works fine, but I need the assembly to register as com.
Thanks for your help
I think you need to sign the assembly.
wrote in message news:5345204@discussion.autodesk.com...
Hi Tony
To be able to sign, I guess you meant uncheck the com options and then compile the project by selecting the sign with strong name option?. The thing is once I do that, how can I expose the assembly as com?. I checked some tools like Regasm.exe to do that, I try that over the weekend.
andy62
I have the same problem! 😞
when I debug a solution return the follow error:
Error 1 Cannot register assembly "C:\Applica\ACadMap\AcadMapAddIn\AcadMapAddIn\AcadMapAddIn\bin\Debug\AcadMapAddIn.dll". The specified module could not be found. (Exception from HRESULT: 0x8007007E) AcadMapAddIn
when I add the sign retun also the follow:
Error 2 Unable to emit assembly: Referenced assembly 'acdbmgd' does not have a strong name AcadMapAddIn
terrible!
andrea
”Boost
