.NET
Valued Contributor
RamanSBV
Message 1 of 4 (216 Views)
Can i close the inactive drawing file using c#?
216 Views, 3 Replies
03-04-2013 03:15 AM
I need to close drawing file which is inactive. Please guide me how i can achive same.
Raman
*Expert Elite*
norman.yuan
Message 2 of 4 (190 Views)
Re: Can i close the inactive drawing file using c#?
03-04-2013 12:28 PM in reply to: RamanSBV
Yes, you can close drawing which is not current active drawing (not Application.DocumentManager.MdiActiveDocument) easily.
Here is sample code:
public class MyCommands
    [CommandMethod("CloseTest")]
    public static void CloseNonActiveDrawing()
        Document dwg = Application.DocumentManager.MdiActiveDocument;
        Editor ed = dwg.Editor;
        foreach (Document doc in Application.DocumentManager)
            if (doc.Name != dwg.Name)
                string fName=System.IO.Path.GetFileName(doc.Name);
                doc.CloseAndDiscard();
                ed.WriteMessage("\nDrawing \"{0}\" has been closed!", fName);
                break;
Valued Contributor
RamanSBV
Message 3 of 4 (181 Views)
03-04-2013 08:51 PM in reply to: norman.yuan
Thanks for your respose on this issue.
If i use above code to close the drawing file, all changes are going away.
I want to save the changes with close.
Please guide me
Raman
Moderator
Alexander.Rivilis
Message 4 of 4 (168 Views)
03-05-2013 04:08 AM in reply to: RamanSBV
Try to change:
 with:
doc.CloseAndSave(doc.Name);
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
You are not logged in.
Announcements
Need installation help?
Ask the Community
