.NET
Can I keep a modeless Dialog permanently?
2 REPLIES 2
644 Views, 2 Replies
Hello Gentlemen,
  1. Is it possible to keep a modeless dialog box permanently open (aside) just like a properties or tool pallete dialog box?
  2. If Yes, by keeping permanently, can I work in autocad environment normally as usual, like save, edit, close and open other drawings?
Note: Just assume that I am making a calculator-like dialog box. I would like to keep it open till the autocad application closes? (even in zero document mode.)
2 REPLIES 2
Thank you mzakiralam.
Thanks for your link
”Boost
