.NET
Distinguished Contributor
NathTay
Message 11 of 20 (151 Views)
Re: Can GRDRAW be done with VB.net?
09-18-2005 04:03 PM in reply to: *James Maeding
Hi Albert, do you know if it will be in the .NET API in a future release?
Regards - Nathan
*James Maeding
Message 12 of 20 (151 Views)
09-18-2005 09:55 PM in reply to: *James Maeding
Wow, this gets deep fast. I am starting to see how different .net is.
I looked at the helloworld prog in the objectarx sdk download and how it uses the transaction manager to do things.
It looks like I am doing objectarx programming in visual basic.
I am ok with learning but this is such a twist. Now the divide between programming in lisp and VB (vb.net) is huge.
I can teach someone lisp writing pretty fast, but you have to know a whole lot and be practiced at vb.net to write
vb.net progs for acad.
Am I the only one who thinks vb.net learning curve is way beyond the time availablity of most cad managers?
Its like you become a very well educated programmer, or your complicated projects written in VB6 become incompatible
with acad some time soon.
Is my read on all this wrong?
Albert, you're right. I figured it out while trying to reproduce that API call from VB6... James, I guess you can still
write acedGrDraw function (as explained) in VB.NET, exposing it to VB6 via COM Interop.
Useful links on exposing COM Interfaces of .NET classes:
- http://www.codeproject.com/vb/net/MusaExposingCOM.asp (VB.NET, early and late binding)
- http://www.codeproject.com/dotnet/COM_DOTNET_INTEROP.asp (COM Interop, explained)
- http://www.codeproject.com/dotnet/cominterop.asp (C#, see Part II)
- http://www.codeproject.com/csharp/CSComTemplate.asp (COM Class wizard in C#)
Maksim Sestic
James Maeding
Civil Engineer and Programmer
jmaeding - athunsaker - com
*Tony Tanzillo
Message 13 of 20 (151 Views)
09-18-2005 10:47 PM in reply to: *James Maeding
>> James Maeding
You SIG doesn't say 'cad manager'.
*James Maeding
Message 14 of 20 (151 Views)
09-19-2005 08:44 AM in reply to: *James Maeding
But that is what I do, I am a full time support person.
I did civil design for 10 years and learned programming along the way, as well as troubleshooting and organizing
projects, like most cad managers.
The difference is I like programming a lot while many cad managers just settle for what others can produce.
You can see that I am not a computer science major though.
Jsut out of curiousity Tony, how did you get into the acad side of programming and what makes up your bread and butter
these days?
My biggest programming effort is the in house civil design prog we use. My day to day is helping project teams get past
hurdles. this inclused everything from interviewing new hires to fixing broken drawings. I like it.
Tony Tanzillo
|>>> James Maeding
James Maeding
*Albert Szilvasy
Message 15 of 20 (151 Views)
09-19-2005 08:53 PM in reply to: *James Maeding
I can't disclose anything about future releases.
Sorry,
albert
wrote in message news:4959802@discussion.autodesk.com...
Regards - Nathan
*Albert Szilvasy
Message 16 of 20 (151 Views)
09-19-2005 08:54 PM in reply to: *James Maeding
Hold it. Don't confuse the API and the language.
You can use VB.NET to program against the COM API just like you did with
VB6.
You can also use VB.NET to program against the .NET API.
In fact you can mix the 2 APIs in the same project or function.
albert
"James Maeding" wrote in message
news:4959900@discussion.autodesk.com...
COM Interop.
late binding)
explained)
C#)
Maksim Sestic
James Maeding
NathTay
Message 17 of 20 (151 Views)
09-19-2005 09:33 PM in reply to: *James Maeding
No worries.
*James Maeding
Message 18 of 20 (151 Views)
09-20-2005 10:07 AM in reply to: *James Maeding
well, I would stick with VB6 if I wanted to do progs that just used com.
I understand that you can do both com and .net api with .net.
I have found I can write much slicker apps with lisp and objectdcl than with VB6/VBA and com.
This is because lisp is hooked up better with the acad command line than com is.
For instance,
Can you write a function with com that asks the user to pick an entity or type a number?
This is important for routines that need an elevation to do something, and the user might have some text already drawn
with that elevation in it.
I could not do this with com but am hoping the .net api will give more control of user input...
the GRDraw is another thing that handicapped com, until now...
thx
Albert Szilvasy
|>VB6.
|>albert
James Maeding
*Maksim Sestic
Message 19 of 20 (151 Views)
09-20-2005 11:21 PM in reply to: *James Maeding
Yes, you can. .NET might give
you a slightly more power to control user input than existing COM interface. On
the other hand, .NET will surely help you develop more integrated and more
complex applications, without fear of DLL incompatibility, etc.
*Tony Tanzillo
Message 20 of 20 (151 Views)
09-21-2005 06:04 AM in reply to: *James Maeding
>> For instance, Can you write a function with com
Well, you must not know very much about COM if you
ask a question like that.
Of course you can do that with COM.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
You are not logged in.
Announcements
Need installation help?
Ask the Community
