• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    *pkirill
    Call rejected by Callee?
    687 Views, 5 Replies
    07-20-2005 05:15 AM
    I've got a batch processing program that was
    created in .NET. So far, so good - but the main issue I have left to resolve is
    that if AutoCAD is open and the user has left a command active in one of the
    document windows (2005 and/or 2006), the processor throws an exception "Call was
    rejected by callee". Can anyone help me with a way to get the processor look for
    an active command and if found, cancel it?  I'm assuming a try/catch will
    do it, I just don't know how to format it.
    Thanks for any help!
    Please use plain text.
    *pkirill
    Re: Call rejected by Callee?
    07-20-2005 05:19 AM in reply to: *pkirill
    This is my "Detect AutoCAD" sub if it's any
    help...
    Sub DetectAcadSession()
      blnAcadExist =
    False
     On Error Resume Next
        acad = GetObject(,
    "autocad.application")
        If Err().Number <> 0
    Then
           blnAcadExist =
    False
           acad = New
    AcadApplication
           While blnAcState =
    False
               AcState =
    acad.GetAcadState
    If AcState.IsQuiescent
    Then
    blnAcState =
    True
               End
    If
          End While
    Else
          blnAcadExist =
    True
     Err().Clear()
     ACADVer =
    acad.Version.ToString()
    End Sub
    Distinguished Contributor
    07-25-2005 06:21 AM in reply to: *pkirill
    Kill the active command
    Public Function KillAutoCADCommand(ByVal AcadDoc As AutoCAD.AcadDocument) As Boolean
    ''' 10.19.04 TMH Made argument optional so you can just grab the current AutoCAD instance.
    Dim AutoCADPending As Boolean = True
    Dim strTemp As String
    Dim i As Integer
    Try
    EnumWindows(AddressOf EnumWinProc, 0)
    PostMessage(gAutoCADHwnd, WM_KEYUP, 27, 0)
    ' The following loop needs to be performed in order to make sure the
    ' PostMessage API has performed the cancel in AutoCAD before proceeding
    Do Until AutoCADPending = False
    Try
    strTemp = AcadDoc.Name
    Catch ex As Exception
    AutoCADPending = True
    End Try
    Loop
    MsgBox(ex.Message)
    End Try
    End Function
    *pkirill
    07-27-2005 08:51 AM in reply to: *pkirill
    That's great - Much Thanks!
    Paul
    wrote in message news:4909926@discussion.autodesk.com...
    Boolean
    Dim i As Integer
    Try
    the
    proceeding
    Try
    End Try
    Loop
    MsgBox(ex.Message)
    End Try
    End Function
    Active Member
    08-01-2005 02:23 PM in reply to: *pkirill
    Hi -
    I think I am experiencing the same kind of problem that the OP has. What I am trying to do is open up a file, go through all of the block references and explode with the "-explode" command. I'm doing this through VB.NET via a "SendCommand" call. I know the handle to the block ref, so I do this:
    acadDoc.SendCommand("(command ""-explode"" (handent """ & strHandle & """))" & vbCrLf)
    The problem is that works once, and subsequent calls blow up with the "call rejected by callee" exception. I'm suspecting it's the same deal as the OP. One other wierdness is when I call that, AutoCAD's help file pops up. AutoCAD's main window also tends to want to show itself as well, no matter what I set it's visibility to.
    With that said, I'm trying to get this EnumWindows thing working, and I was wondering if you could post the rest of the code. I'm having problems declaring the Win32 API functions, and nothing I've found on the web is working. I'm assuming that something like this should work:
    Public Delegate Function CallBack(ByVal handle As Integer, ByVal param As Integer) As Boolean
    Declare Function EnumWindows Lib "user32" _
    (ByVal lpEnumFunc As CallBack, _
    ByVal lParam As Integer) As Integer
    Declare Function PostMessage Lib "user32" Alias _
    "PostMessageA" (ByVal hwnd As Long, ByVal wMsg As Long, _
    ByVal wParam As Long, ByVal lParam As Long) As Long
    Declare Function GetWindowText Lib "user32" Alias _
    "GetWindowTextA" (ByVal hwnd As Long, _
    ByVal lpString As String, ByVal cch As Long) As Long
    Private Const WM_KEYUP As Long = &H101
    Public Function WndEnumProc(ByVal handle As Integer, _
    Dim lResult As Long
    Dim sWndName As String
    WndEnumProc = 1
    lResult = GetWindowText(handle, sWndName, 255)
    ' And I assume that if sWndName has "AutoCAD" in it
    ' or something like that, we set gAutoCADHwnd to it
    End Function
    I have to do the "Callback" thing apprarently because the AddressOf thing needs it based on the MSDN docs.
    The problem I see is that GetWindowText is not giving me anything at all. lResult is garbage. If I set a breakpoint and go through, I get LOTS AND LOTS of handles, seemingly more than I expect, and nothing with which GetWindowText works.
    One other question tho - Instead of using EnumWindows, why not use AcadApplication.HWND? I still don't have any success doing a PostMessage to that, but I'm still curious. I know this is a hairy question, but any help is appreciated.
    Thanks!
    Valued Contributor
    05-27-2010 10:44 AM in reply to: *pkirill
    I'm using VB.Net 2008 and the following lines of code from your post do not work for me.
    What do I need to do to make these work?
    Thank you,
    Eric
