.NET
Active Contributor
pva75
Message 1 of 2 (170 Views)
Call COM object from AutoCad 2011
170 Views, 1 Replies
07-22-2012 12:16 PM
I tried to call COM object created by C# from other C# module.
I did:
1. Create simple COM object by C#
2. Register it
3. Try to call this COM from other C# console application - it works fine
4. Create simple AutoCad module by C# with IExtensionApplication
5. Try to call this module from AutoCAD - it works
6. In Initialize() method I wrote:
Type myClassAdapterType = Type.GetTypeFromProgID("CoreAdapter.CoreAdapterClass");
 acDoc.Editor.WriteMessage("Type is OK: {0}", myClassAdapterType.FullName);
 object myClassAdapterInstance = Activator.CreateInstance(myClassAdapterType);
acDoc.Editor.WriteMessage("Created");
6. Open AutoCAD again
7. Load my module
8. I saw "Type is OK" (becase it was registered in registry)
But I can't create instance.
Can you help me?
ADN Support Specialist
Virupaksha.aithal
Message 2 of 2 (128 Views)
Re: Call COM object from AutoCad 2011
07-26-2012 03:41 AM in reply to: pva75
Hi
It is tough to suggest from the information you have provide.
So, I will try to suggest few suggestions…
  1. First as test, implement a command in AutoCAD plug-in and try to instance in the command.
  2. Check whether your code is throwing any exception by using try and catch block
  3. Also try to add new line character “\n” in your “WriteMessage” like “ed.WriteMessage("Test" + "\n");
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Ask the Community
