• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    [C#] Creating a new Text Style and how to use it or assign it
    315 Views, 3 Replies
    11-26-2012 02:15 PM
    Hello all ^^
    I want to programatically create a text style in the current database based on a font located in the AutoCAD /fonts folder. After that, I want to assign that text style to a newly created DBText.
    I am close but can't quite get it. Let's see what I have:
    (I have 2 commented lines that I stumbled upon but I'm not sure they helped because I still got errors and left it as comment.
    using (Transaction newTransaction = newDoc.Database.TransactionManager.StartTransaction())
      TextStyleTable newTextStyleTable = newTransaction.GetObject(newDoc.Database.TextStyleTableId, OpenMode.ForRead) as TextStyleTable;
      if (!newTextStyleTable.Has("ROMANS"))  //The TextStyle is currently not in the database
        newTextStyleTable.UpgradeOpen();
        newTextStyleTableRecord = new TextStyleTableRecord();
        newTextStyleTableRecord.FileName = "romans.shx";
        newTextStyleTableRecord.Name = "ROMANS";
        //Autodesk.AutoCAD.GraphicsInterface.FontDescriptor myNewTextStyle = new Autodesk.AutoCAD.GraphicsInterface.FontDescriptor("ROMANS", false, false, 0, 0);
        //newTextStyleTableRecord.Font = myNewTextStyle;
        newTextStyleTable.Add(newTextStyleTableRecord);
        newTransaction.AddNewlyCreatedDBObject(newTextStyleTableRecord, true);
      DBText newDBText = new DBText();
      newDBText.SetDatabaseDefaults();
    textEspecificacion.Position = new Point3d(0,0,0); newDBText.Height = 7.0; newDBText.TextString = "HELLO"; newDBText.TextStyleID = newTextStyleTable.GetField("ROMANS"); newBlockTableRecord.AppendEntity(newDBText); newTransaction.AddNewlyCreatedDBObject(newDBText, true); newTransaction.Commit(); }
     Please tell me what I'm doing wrong.
    I get key not found error.
    Do i have to lock the document?
    Thanks in advance :smileyvery-happy:
    <3 you all
    but I love my gf more :smileyvery-happy:DDDDDDDDDD XD
    Please use plain text.
    Re: [C#] Creating a new Text Style and how to use it or assign it
    11-27-2012 06:44 AM in reply to: DouceDeux
    Try change this:
    to
    newDBText.TextStyleID = newTextStyleTable[ROMANS"];
    Active Contributor
    11-27-2012 10:59 AM in reply to: DouceDeux
    That worked!
    Do you know why one line didn't work .GetField(...) (eKeyNotFound) and the other did?
    Is the TextStyleTable an enumerable itself where the text styles are saved?
    P.S. I'll try to edit my first post for forum knowledgebase purposes
    Active Contributor
    Final code
    11-27-2012 11:13 AM in reply to: DouceDeux
    Correcting my first code and adding the help from the solution we have:
      BlockTable newBlockTable;
      newBlockTable = newTransaction.GetObject(newDoc.Database.BlockTableId, OpenMode.ForRead) as BlockTable;
      BlockTableRecord newBlockTableRecord;
      newBlockTableRecord = (BlockTableRecord)newTransaction.GetObject(newBlockTable[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
      newDBText.TextStyleID = newTextStyleTable["ROMANS"];
     I hope this helps other new people like me.
    Thanks for the help.
    Next new topic... String keywords... :smileyvery-happy:DDDDDD
