.NET
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Build for multiple Autocad versions
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
05-19-2005 02:05 PM in reply to:
ChrisArps
I tried this yesterday testing a new program, ADT 2006 will not even run after changing the config file.
I have no idea about Autocad2006, but I suspect it will crash as well.
*Laurence Skoropinski
Options
- Highlight
- Email to a Friend
05-20-2005 12:07 AM in reply to:
ChrisArps
Cheers, thanks for the full explanation, will give it a go
Laurence
wrote in message news:4851112@discussion.autodesk.com...
Sure, the first two steps you will have to do manually to setup for your
compiles/builds.
1) Locate the Autodesk .dll files in the GAC. You cannot use windows
explorer for this, you have to use the good old command line with cd and
dir.
CD \winnt\assembly\GAC
xcopy *.* c:\temp\junk /S
This will copy all the subdirs and all dlls in the gac so you can get at
them with explorer.
2) Find the appropriate Autodesk folders and copy the dlls to a nice
location for your builds for ease of use.You will need a folder for each
version.
Now that we have the dotnet dlls you can now setup for builds.
Assuming we are building the 2006 version of the program:
3) Execute the unregister batch file for 2005 (shown below)
cd Assembly
cd ADT45
%Framework%\regasm Autodesk.AEC.Interop.ArchBase.dll /u
%Framework%\regasm Autodesk.AEC.Interop.Base.dll /u
%Framework%\regasm Autodesk.AEC.Interop.UIArchBase.dll /u
%Framework%\regasm Autodesk.AEC.Interop.UIBase.dll /u
%Framework%\regasm Autodesk.AutoCAD.Interop.dll /u
%Framework%\regasm Autodesk.AutoCAD.Interop.Common.dll /u
cd ..
cd ..
if (%1)==(AUTO) goto :EOF
pause
4) Execute the register batch file for 2006 (shown below)
cd Assembly
cd ADT47
cd ..
cd ..
pause
There are 4 batch files, reg and unreg for 2005, reg and unreg for 2006.
Thist allows a developer to be on 2006 and we can build for both versions
(as long as he doesn't use any 2006 only features).
Laurence
compiles/builds.
dir.
them with explorer.
version.
cd Assembly
cd ADT45
cd ..
cd ..
pause
cd Assembly
cd ADT47
cd ..
cd ..
pause
Options
- Highlight
- Email to a Friend
05-20-2005 01:32 AM in reply to:
ChrisArps
Can you just confirm the version numbers please. I have v16.2.54.0 which I
assume is 2006 and version 16.1.63.0 which I assume is 2005?
Laurence
compiles/builds.
dir.
them with explorer.
version.
cd Assembly
cd ADT45
cd ..
cd ..
pause
cd Assembly
cd ADT47
cd ..
cd ..
pause
Laurence
compiles/builds.
dir.
them with explorer.
version.
cd Assembly
cd ADT45
cd ..
cd ..
pause
cd Assembly
cd ADT47
cd ..
cd ..
pause
Options
- Highlight
- Email to a Friend
05-20-2005 02:59 AM in reply to:
ChrisArps
My fault, test PC has 2006 so uninstalled and tried, failed, so repaired
2005 installation, worked.
Batch files - Great solution CArps
Laurence
"Laurence Skoropinski" wrote in message
news:4851451@discussion.autodesk.com...
Laurence
compiles/builds.
dir.
them with explorer.
version.
cd Assembly
cd ADT45
cd ..
cd ..
pause
cd Assembly
cd ADT47
cd ..
cd ..
pause
Laurence
Laurence
compiles/builds.
dir.
them with explorer.
version.
cd Assembly
cd ADT45
cd ..
cd ..
pause
cd Assembly
cd ADT47
cd ..
cd ..
pause
Options
- Highlight
- Email to a Friend
05-20-2005 05:26 AM in reply to:
ChrisArps
I tried that out and it will work, but I lose the AcGe library in 2005,2006 code. I will just stick to the batch trick as it only affects the build machine and does not impact development environments.
Options
- Highlight
- Email to a Friend
06-15-2005 02:07 PM in reply to:
ChrisArps
I too am trying to build for 2 versions, vanilla ACAD 2005 & 2006. I am also learning vb.net. I tried the batch trick you described below but it didn't work. regasm told me that all registers and unregisters were successfull. I am still getting errors for ALL of my Imports such as this:
Namespace or type 'ApplicationServices' for the Imports 'Autodesk.AutoCAD.ApplicationServices' cannot be found.
Anybody know what I am doing wrong? I have correctly referenced the right AutoCAD DLL's.
Options
- Highlight
- Email to a Friend
08-22-2006 07:22 AM in reply to:
ChrisArps
CArps, this is a really great work! I will try this too.
Message was edited by: cadprog
