.NET
Bottom Middle and Top Middle DBText Object not aligning correctly
4 REPLIES 4
1105 Views, 4 Replies
Hi Guys,
I have a routine that draws a piece of text.
It works very well except if I use the "Bottom Middle or Top Middle" Alignment.
It draws it but appears as "Middle Middle" alignment.
After placement I change the Justification with AutoCAD Properties Dialog and set it back again to Bottom Middle and every appears correctly.
Anyone Got any Ideas?
Tr = CurDb.TransactionManager.StartTransaction()
            Try
                Using Tr
                    Dim BlkTable As BlockTable = Tr.GetObject(CurDb.BlockTableId, OpenMode.ForRead)
                    Dim BlkRableRec As BlockTableRecord = Tr.GetObject(BlkTable(BlockTableRecord.PaperSpace), OpenMode.ForWrite)
                    Dim NewText As DBText = New DBText
                    NewText.SetDatabaseDefaults()
                    NewText.Position = New Point3d(InsertPoint.asArray)
                    NewText.Height = Data.TextHeight
                    NewText.TextString = Data.LabelPrefix + RetData + Data.LabelSuffix
                    NewText.Rotation = Data.ActualAngle
                    Dim AlignmentFlagSet As Boolean = False
                    Select Case Data.TextAlignment
                        Case "Top_Left"
                            NewText.HorizontalMode = TextHorizontalMode.TextLeft
                            NewText.VerticalMode = TextVerticalMode.TextTop
                            AlignmentFlagSet = True
                        Case "Top_Middle"
                            NewText.HorizontalMode = TextHorizontalMode.TextMid
                        Case "Top_Right"
                            NewText.HorizontalMode = TextHorizontalMode.TextRight
                        Case "Middle_Left"
                            NewText.VerticalMode = TextVerticalMode.TextVerticalMid
                        Case "Middle_Middle"
                        Case "Middle_Right"
                        Case "Bottom_Left"
                            NewText.VerticalMode = TextVerticalMode.TextBottom
                        Case "Bottom_Middle"
                        Case "Bottom_Right"
                    End Select
                    If AlignmentFlagSet = True Then
                        NewText.AlignmentPoint = New Point3d(AlignPoint.asArray)
                    Else
                        Ed.WriteMessage("Alignment Point Skipped!" + vbCrLf)
                    'added to fix alignment issue
                    'Dim WDB As Database = HostApplicationServices.WorkingDatabase
                    'HostApplicationServices.WorkingDatabase = CurDb
                    'NewText.AdjustAlignment(CurDb)
                    'HostApplicationServices.WorkingDatabase = WDB
                    NewText.TextStyleId = GetTextStyleID(Data.TextStyle)
                    NewText.LayerId = GetLayerID(Data.LabelLayer)
                    BlkRableRec.AppendEntity(NewText)
                    Tr.AddNewlyCreatedDBObject(NewText, True)
                    Tr.Commit()
                End Using
            Catch ex As System.Exception
                'Something
                Ed.WriteMessage(ex.Message)
            Finally
            End Try
4 REPLIES 4
hgasty1001
Not sure, but i think that if the text is aligned you have to set only the AlignmentPoint, in other words, delete the line with NewText.Position=..., and set its position only if the text has NOT  an aligment flag.
Gaston Nunez
absStructural
in reply to: hgasty1001
I have noticed the same thing - and typically write something like:
if(DBText.IsDefaultAlignment)
DBText.Position = pt;
else
DBText.AlignmentPoint = pt;
in reply to: absStructural
Thanks guys Ill give it a go and get back to you.
Stephan
OK Chaps,
Solution found....  And what a crappy solution.
When placing Text TOP MIDDLE or BOTTOM MIDDLE
You can use the a
TextHorizontalMode.TextCenter
 But  the rest use (When refering to the middle of the text
when refering to the middle... GRRRRR
Stephan
”Boost
