.NET
Active Contributor
s.hofer
Message 1 of 9 (615 Views)
Blocks on the same layer To group
615 Views, 8 Replies
08-15-2011 04:16 AM
My script in VBA works perfect. Now i try to do the same with NET, but nothing happens.
here is the code:
    Public Function CreateSelectionSet(ByVal SelectionSet As AcadSelectionSet, _
    ByVal FilterCode As Integer, _
    ByVal FilterValue As String) As Boolean
        Dim iFilterCode(0) As Integer
        Dim vFilterValue(0) As Object
        iFilterCode(0) = FilterCode
        vFilterValue(0) = FilterValue
        SelectionSet.Select(AcSelect.acSelectionSetAll, , , iFilterCode, vFilterValue) '<-VB.NET
        'SelectionSet.Select acSelectionSetAll, , , iFilterCode, vFilterValue '<- VBA
        If SelectionSet.Count Then
            CreateSelectionSet = True
        End If
    End Function
    <Autodesk.AutoCAD.Runtime.CommandMethod("GROUPLAYER")> _
    Public Sub GroupLayer()
        On Error GoTo ErrTrap
        Dim objEnts() As AcadEntity
        Dim intIndex As Integer
        Dim objGrp As AcadGroup
        Dim LayerName As String
        Dim oBlkRef As AcadBlockReference
        Dim basePnt As Object
        ThisDrawing.Utility.GetEntity(oBlkRef, basePnt, "Layer zu Gruppe -> Objekt wählen...")
        LayerName = oBlkRef.Layer
        Dim iType(0) As Integer
        Dim objSS As AcadSelectionSet
        iType(0) = 8
        On Error Resume Next
        'delete any previous selection set
        ThisDrawing.SelectionSets("Entities").Delete()
        'create our new selection set
        objSS = ThisDrawing.SelectionSets.Add("Entities")
        'get the actual entities for the selection set
        CreateSelectionSet(objSS, iType(0), LayerName)
        'Gruppe erstellen
        ReDim objEnts(objSS.Count - 1)
        For intIndex = LBound(objEnts) To UBound(objEnts)
            objEnts(intIndex) = objSS(intIndex)
        Next intIndex
        objGrp = ThisDrawing.Groups.Add("*")
        objGrp.AppendItems(objEnts)
ErrTrap:
        Err.Clear()
    End Sub
 I can select something, but nothing happens...
where is the error?
norman.yuan
Message 2 of 9 (599 Views)
Re: Blocks on the same layer To group
08-15-2011 06:53 AM in reply to: s.hofer
Have you stepped through your code in debugging, which could reveal the cuase of your issue easily?
Firstly, never use On Error Resume Next without examine Err object after every line of code if you code may run into unexpected exceptions (often one can NEVER be asure of this). In your case, this is the answert to your question ("Where is the error"). Since you have already moved to VB.NET, you should use more friendly Try...Catch...exception handling structure instead.
Secondly, if the SelectionSet is actually created, I'd bet it may contains 0 entity. Since CreateSelection() is a function returning True/False, you should call it coorectly:
If CreateSelectionSet(....) Then
    'Group things
Else
    'Prompt user for no entity being selected, if necessary
End
This way, at least you will be clear that "nothing happens" could be the result of no entity being selected.
Thirdly, If your intetion is to select only block references on certain layer, you may want to redefine your filter group code to combine both "LAYER" and "INSERT" as filter. Otherwise, as your cdoe, any entity on the layer, being block or not, will also be selelcted and placed into the group.
Finally, now that you are doing .NET, why use COM API instead of .NET API?
Active Contributor
s.hofer
Message 3 of 9 (575 Views)
08-16-2011 07:36 AM in reply to: norman.yuan
... right, it was nothing selected.
i replaced the "FilterType As Integer" with Short and now it works.
i'm not good with vba and i'm a newbie with NET, -> no errors = perfect for me.
here is my code, works (okay you still get errors if you dont pick a Block) but who cares. :smileyhappy:
        ThisDrawing.Utility.GetEntity(oBlkRef, basePnt, "Layer zu Gruppe -> Block wählen...")
        Dim FilterType(0 To 1) As Short
        Dim FilterData(0 To 1) As Object
        FilterType(0) = 0
        FilterData(0) = "INSERT"
        FilterType(1) = 8
        FilterData(1) = LayerName
        Dim FilterTypeObject As Object
        Dim FilterDataObject As Object
        FilterTypeObject = FilterType
        FilterDataObject = FilterData
        'Bestehendes SelectionSet Löschen
        For i = 0 To ThisDrawing.SelectionSets.Count - 1
            If ThisDrawing.SelectionSets.Item(i).Name = "Entities" Then
                ThisDrawing.SelectionSets.Item(i).Delete()
            End If
        Next i
        'SelectionSet Erstellen
        objSS.Select(AcSelect.acSelectionSetAll, , , FilterTypeObject, FilterDataObject) '<-VB.NET
        'Gruppe erstellen
        Next intIndex
    End Sub
ty for help.
norman.yuan
Message 4 of 9 (571 Views)
08-16-2011 07:50 AM in reply to: s.hofer
You'd better still test whether the SelectionSet.Count>0 or not before this line
If the SelectionCount=0 for some reason, the "ReDim" statement would raise Exception and your command would crash AutoCAD, which I assume you do care.
Active Contributor
s.hofer
Message 5 of 9 (556 Views)
08-16-2011 11:25 PM in reply to: norman.yuan
okay.
i added the "On Error GoTo" Line again. I get no warnings or errors now.
        'Prüfen ob Selectionset nicht leer
        If objSS.Count > 0 Then
            'Gruppe erstellen
            Next intIndex
        End If
ErrTrap:
        Err.Clear()
End Sub
ADN Support Specialist
Balaji_Ram
Message 6 of 9 (549 Views)
08-17-2011 02:11 AM in reply to: s.hofer
Here is a code snippet that makes a group out of all the blocks in a specified layer.
<CommandMethod(
"Test")> _
Public Sub commandMethodTest()
Dim activeDoc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = activeDoc.Database
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim pso As New PromptStringOptions(
"Layer Name :")
pso.DefaultValue =
"0"
pso.AllowSpaces = False
Dim pr As PromptResult = ed.GetString(pso)
If pr.Status <> PromptStatus.OK Then
Return
End If
Dim filterData As TypedValue() = {
New TypedValue(CInt(DxfCode.LayerName), pr.StringResult),
New TypedValue(CInt(DxfCode.Start),
"INSERT")
Dim selFilter As New SelectionFilter(filterData)
Dim promptReslt As PromptSelectionResult = ed.SelectAll(selFilter)
Dim ss As SelectionSet = promptReslt.Value
If ss IsNot Nothing AndAlso ss.Count > 0 Then
Using tr As Transaction = db.TransactionManager.StartTransaction()
Dim gd As DBDictionary = DirectCast(tr.GetObject(db.GroupDictionaryId, OpenMode.ForWrite), DBDictionary)
Dim grp As New Group(pr.StringResult, True)
Dim ids As New ObjectIdCollection(ss.GetObjectIds())
grp.Append(ids)
gd.SetAt(pr.StringResult, grp)
tr.AddNewlyCreatedDBObject(grp, True)
tr.Commit()
End Using
End If
End Sub
Balaji
Developer Technical Services
Autodesk Developer Network
Active Member
mikecarrico7670
Message 7 of 9 (329 Views)
12-17-2012 03:40 PM in reply to: Balaji_Ram
Balaji,
I was trying to use your code to create a group and add three specific objects to it stored in memory.  Part of my difficulty is that this program was started with AutoCAD Interop objects and not leveraging the DatabaseServices model.      I attempted to first use the Acadgroup object to achieve this but with no luck.  So far I have the following code to create a group and add 3 objects to it (mtext, block, table).  Please note, this code is not pretty and is a mismash of interop code and databaseservices; please don't cringe too much.
Ultimately, the code creates the group succesfully in model space but does not create the group if I go to the Groups window.  I was hoping that you could possibly help me figure out what I was doing wrong and also direct me to a source where I could better understand some of the functions used below (SetAt, the declaration of the DBDictionary, etc.).  I am still fairly new to AutoCAD .net programming and a resource such as an MSDN type class breakdown would be very much appreciated.
Dim activeDoc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim grp As New Group("MESCHGroup", True)
'Dim ids As New ObjectIdCollection(ss.GetObjectIds)
Dim ids As New ObjectIdCollection()
Dim oid1 As New ObjectId(headerBlock.ObjectID)
ids.Add(oid1)
Dim oid2 As New ObjectId(mt.ObjectID)
ids.Add(oid2)
Dim oid3 As New ObjectId(HVACtable.ObjectID)
ids.Add(oid3)
Try
grp.Append(ids)
gd.SetAt("*", grp)
Catch ex As Exception
MsgBox(ex.Message)
End Try
tr.Commit()
End Using
Mike
Active Member
mikecarrico7670
Message 8 of 9 (315 Views)
12-18-2012 07:10 AM in reply to: mikecarrico7670
Just as a follow up to my question, I was able to get this working using interop objects with the following code:
Dim meschgroup As AcadGroup = ThisDrawing.Groups.Add("MESCHGroup")
Dim oarray As AcadEntity() = {mt, headerBlock, HVACtable}
Try
meschgroup.AppendItems(oarray)
MsgBox(ex.Message)
End Try
Any help in directing me towards documentation of the databaseservices model would still be greatly appreciated.
Balaji_Ram
Message 9 of 9 (298 Views)
12-20-2012 10:34 PM in reply to: mikecarrico7670
Hi Mike,
Sorry for not getting back to you in time for your recent query.
Good to know that you have found the solution.
Regarding the class hierarchy, you can refer to the <ObjectARX foder>\Classmap\classmap.dwg
It has the class hierarchy for the ObjectARX and .Net classes.
The managed API documentation (arxmgd.chm) can be helpful if you are tracking the class hierarchy for a given class. If you search for example, "Line class", you can then click through the class hierarchy to find its base classes.
Hope this helps.
Balaji
You are not logged in.
Ask the Community
