.NET
Blocks and Block attributes on Autocad 2006
3 REPLIES 3
Steve-o
334 Views, 3 Replies
Does anyone have an example of how to extract block attribute information (I'm using c#)?
I seem to only be able to get at the *mspace object not any of the actual block references - refer to the following snippet:
//- Get the selection from the user....
//- Loop through each object id
foreach(ObjectId l_oObj in l_oObjs)
BlockReference l_oBlkRef = (BlockReference)m_oTransMgr.GetObject(l_oObj,OpenMode.ForRead);
BlockTableRecord l_oBlkTblRec = (BlockTableRecord)m_oTransMgr.GetObject(l_oBlkRef.BlockId,OpenMode.ForRead);
l_oEditor.WriteMessage("Scanning:" + l_oBlkTblRec.Name);
Any help would be great!
Thanks in advance,
Steve-o
3 REPLIES 3
Mikko
in reply to: Steve-o
Did you get an answer? I'm stumped here.
Dim oid As ObjectId() = ss.GetObjectIds
Dim blkid As ObjectId
For Each blkid In oid
Dim br As BlockReference
br = tr.GetObject(blkid, OpenMode.ForRead, True)
Dim btr As BlockTableRecord
btr = tr.GetObject(br.BlockTableRecord(), OpenMode.ForRead, True)
If btr.HasAttributeDefinitions Then
Dim id As ObjectId
For Each id In btr
Dim ent As Entity = tr.GetObject(id, OpenMode.ForWrite, True)
If TypeOf ent Is AttributeDefinition Then
Dim ad As AttributeDefinition
ad = ent
'ed.WriteMessage(vbCrLf + ad.Tag.ToString + vbCrLf)
'ed.WriteMessage(vbCrLf + ad.Prompt.ToString + vbCrLf)
ed.WriteMessage(vbCrLf + ad.TextString + vbCrLf)
Next
Next
Using textstring gives the default value, not the actual string.
How do you get the typed string?
Mikko
Seemed to have got tangled up for a bit, this works.
Dim ac As AttributeCollection
ac = br.AttributeCollection
If ac.Count > 0 Then
Dim attId As ObjectId
For Each attId In ac
Dim ar As AttributeReference
ar = tr.GetObject(attId, OpenMode.ForRead, False)
ed.WriteMessage(ar.TextString.ToString + vbCrLf)
Next
Rudedog
The OP asked for C#. You seem to have VB replies. I can help you out with a C# solution. (Yeah I know old post. I've searching to see if anyone has solved my problem or at least find some clues.) If you still need a sample, I could post a sample or post a link to samples.. I am still looking to how read dynamic block attributes in C#.
Rudedog
"Fooling computers since 1971."
Message was edited by: Rudedog
Just read the above. It's vague. I am wrestling with...
Autodesk.AutoCAD.Interop.Common.IAcadDynamicBlockReferenceProperty
...or am I on the wrong track.
Trying to modify this sample...
http://through-the-interface.typepad.com/through_the_interface/2007/06/creating_a_tabl.html
...to work with dynamic blocks in 2008.
”Boost
