.NET
Distinguished Contributor
VB_Autocad_guy
Message 1 of 4 (284 Views)
BlockTableRecord vs DynamicBlockTableRecord
284 Views, 3 Replies
03-20-2012 02:32 PM
   For Each myEntID As ObjectId In myBTR
                        Dim myEnt As Entity = myEntID.GetObject(OpenMode.ForRead) 'Read Entity
                        If TypeOf myEnt Is BlockReference Then
                            'If Block Reference
                            Dim myBRef As BlockReference = CType(myEnt, BlockReference)
                            Dim myBlockDef As BlockTableRecord =  myBRef.BlockTableRecord.GetObject(OpenMode.ForRead)
                            'myBRef.DynamicBlockTableRecord.GetObject(OpenMode.ForRead)
What's the differencebetween blocktablerecord and dynamicblocktablerecord?
When I'm trying to access the blocktablerecord what's the difference?
Will blocktablerecord work on dynamic blocks are they somewhat interchangeable?
ADN Support Specialist
adam.nagy
Message 2 of 4 (264 Views)
Re: BlockTableRecord vs DynamicBlockTableRecord
03-20-2012 06:16 PM in reply to: VB_Autocad_guy
HI there,
BlockTableRecord is the actual block record that is being used (i.e. shown) by the block reference.
The DynamicBlockTableRecord is the block (if the block reference is referencing a dynamic block) that the BlockTableRecord instance is based on (it's a specific variation of the dynamic block)
If you are already familiar with the concept of dynamic blocks from a user interface point of view, then the best thing, as always :smileyhappy:, is to use a utility like ArxDbg/MgdDbg and look into the database and see for yourself the relation between the various objects.
I hope this helps.
Cheers,
Adam Nagy
Autodesk Developer Network
Adam Nagy
Developer Technical Services
VB_Autocad_guy
Message 3 of 4 (256 Views)
03-20-2012 08:14 PM in reply to: VB_Autocad_guy
Yah thanks that does help. I'm familiar with arxdbg. I'll fiddle around with it. I believe our site doesn't use many dynamic block.
What's the property or method to see if a block record is dynamic?
adam.nagy
Message 4 of 4 (240 Views)
03-21-2012 01:44 AM in reply to: VB_Autocad_guy
Both BlockTableRecord and BlockReference classes have an IsDynamicBlock property that can be used to tell if the object is (or is referencing) a dynamic block.
Cheers,
Adam
Adam Nagy
You are not logged in.
Ask the Community
