.NET
BlockTableRecord Error " write protected memory"
4 REPLIES 4
459 Views, 4 Replies
Hi all,
I have this code that crash vith visual studio 2005 & Autocad 2006 :
public class DBMain
[CommandMethod("ad_link",CommandFlags.Session )]
public static void OpenDB()
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
Database db = HostApplicationServices.WorkingDatabase;
Transaction trans = db.TransactionManager.StartTransaction();
try
BlockTable bt = (BlockTable)trans.GetObject(HostApplicationServices.WorkingDatabase.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
//BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt["*MODEL_SPACE"], OpenMode.ForRead );
try
int count = 0;
foreach (ObjectId id in btr)
count += 1;
ed.WriteMessage(count.ToString());
catch (SystemException ex)
catch(Autodesk.AutoCAD.Runtime.Exception ex )
finally
trans.Dispose();
in line :
{"Attempted to read or write protected memory. This is often an indication that other memory is corrupt."}
Anyone can help me ?
Thanks in advance
Max
4 REPLIES 4
Your command is registered with CommandFlags.Session,
(meaning it runs in the application context). Hence, you
must lock the Document whose Database you're accessing
before you try to do anything.
Generally, you only need to run your command in the
application context if there is some interaction with
multiple documents (such as closing or opening one,
or changing the active document).
If your command simply operates on the active document,
you don't need CommandFlags.Session.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:5067115@discussion.autodesk.com...
Hi all,
public class DBMain
try
try
int count = 0;
count += 1;
finally
trans.Dispose();
in line :
Thanks in advance
Max
Hi Tony,
I have remove CommandFlags.Session :
[CommandMethod("ad_link")]
bat the error was the same.
How can I do ?
Max
cgay
Max
Try this
[code]
using System;
using System.Collections.Generic;
using System.Text;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace AcadTest
public class DBMain
Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
// if we use the using construct, we don't have to worry about calling trans.dispose
using (Transaction trans = db.TransactionManager.StartTransaction())
try
try
int count = 0;
if (id.IsValid)
count += 1;
trans.Commit;
ed.WriteMessage(ex.Message.ToString());
trans.Abort;
catch (Autodesk.AutoCAD.Runtime.Exception ex)
trans.Abort;
[/code]
Good Luck,
C
What is "SystemException" ? Is there a missing dot there?
Also, I'm not sure I see the rationale behind catching
exceptions to abort the transaction.
While that was necessary in AutoCAD 2005 because the
transaction was not implicitly aborted if Commit() was not
called, I don't see any need for this in 2006-specific code.
wrote in message news:5068780@discussion.autodesk.com...
Max
Try this
[code]
using System;
using System.Text;
namespace AcadTest
public class DBMain
try
try
int count = 0;
if (id.IsValid)
count += 1;
trans.Commit;
trans.Abort;
trans.Abort;
[/code]
Good Luck,
C
”Boost
