.NET
BlockTable case sensitive keys
9 REPLIES 9
Message 1 of 10
matus.brlit
1056 Views, 9 Replies
When I want to test if block with a given name exists in drawing, I use BlockTable.Has(key as String) method, which is case sensitive, but then, when I try to insert a block with the same name, but different case, the block name is considered the same.
How can I test if the block in in the drawing then?
9 REPLIES 9
Message 2 of 10
Sorry, no, it's not case senstitive! You also can't create a block named "XXX" and a block "xxx" coexisting in the same drawing.
How did you test it?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
_gile
in reply to: matus.brlit
By my side, I never saw the SymbolTable.Has(string) method being case sensitive...
Gilles Chanteau
GileCAD
GitHub
Message 4 of 10
- alfred -
That's what I call case sensitive, when a block XXX is in the drawing, BlockTable.Has("xxx") returns False
but then id = db.Insert("xxx", sourceDb, True) fails for some reason, as if there already was a block with that name
I also tried to create blocks "xxx" and "XXX" in AutoCAD IDE. I created block "xxx", then tried to create block "XXX" and I got an error:
A block named "XXX" already exists.
*Invalid*
Message 5 of 10
If a Blockdefinition in your drawing exists with the Name "XXX" or "Xxx" or "xxx" ... the BlockTable.Has("xxx") should return true (does it for me). Can you show a full sample (how you get the blocktable) and a test drawing that gives us the option to try this with your code?
- alfred -
Alfred NESWADBA
Message 6 of 10
_gile
Try this little sample. It add a new block definition named "block" if not already exists and runs BlockTable.Has() with "block", "Block" and "BLOCK".
        <CommandMethod("Test")> _
        Public Sub Test()
            Dim doc As Document = AcApp.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using trans As Transaction = db.TransactionManager.StartTransaction()
                Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForWrite)
                If Not bt.Has("block") Then
                    Dim btr As BlockTableRecord = New BlockTableRecord()
                    btr.Name = "block"
                    Dim circ As Circle = New Circle(Point3d.Origin, Vector3d.ZAxis, 10.0)
                    bt.Add(btr)
                    trans.AddNewlyCreatedDBObject(btr, True)
                    btr.AppendEntity(circ)
                    trans.AddNewlyCreatedDBObject(circ, True)
                trans.Commit()
                ed.WriteMessage(String.Format("{0}Has 'block': {1}", vbLf, bt.Has("block")))
                ed.WriteMessage(String.Format("{0}Has 'Block': {1}", vbLf, bt.Has("Block")))
                ed.WriteMessage(String.Format("{0}Has 'BLOCK': {1}", vbLf, bt.Has("BLOCK")))
            End Using
        End Sub
Gilles Chanteau
GileCAD
GitHub
Message 7 of 10
matus.brlit
you are right with the case sensitivity, it's not case sensitive, I missed one more difference in the name, one has underscore "_" and the other has dash "-" in the name
If I have one of them in the drawing, then my code throws an exception, when trying to insert the other one:
Managed Debugging Assistant 'FatalExecutionEngineError' has detected a problem in 'E:\AutoCAD Civil 3D 2013\acad.exe'.
Additional Information: The runtime has encountered a fatal error. The address of the error was at 0xf4a4d4cc, on thread 0x1218. The error code is 0xc0000005. This error may be a bug in the CLR or in the unsafe or non-verifiable portions of user code. Common sources of this bug include user marshaling errors for COM-interop or PInvoke, which may corrupt the stack.
After some more tests, I found out interresting things. The names of the blocks are: 0413_R1_ZVODIDLA_rozpiska and 0413_R1_Zvodidla-rozpiska
I tried to change the second name to 0413_R1_Zvodidla-rozpiska - kópia and 0413-rozpiska; both failed upon insert, then I renamed it to 123456 and I was able to insert it.
Here's my code for inserting the block:
Using sourceDb As Database = New Database(False, True)
      sourceDb.ReadDwgFile(dwgPath, FileShare.ReadWrite, True, "")
      id = db.Insert(blkName, sourceDb, True)
 End Using
Message 8 of 10
matus.brlit
any idea, what this could be?
Message 9 of 10
Balaji_Ram
Have you tried it in AutoCAD UI without the API ?
The crash does not seem to be related to the block name/ drawing name.
Here is the code snippet that I tried with two sample drawings created using AutoCAD 2013 and it worked ok.
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
using (DocumentLock docLock = doc.LockDocument())
    string dwgPath1 = @"C:\Temp\0413_R1_Zvodidla-rozpiska.dwg";
    using (Database dbSource = new Database(false, true))
        dbSource.ReadDwgFile(dwgPath1, FileShare.ReadWrite, true, null);
        ObjectId id1 = db.Insert("0413_R1_Zvodidla-rozpiska", dbSource, true);
    string dwgPath2 = @"C:\Temp\0413_R1_Zvodidla_rozpiska.dwg";
        dbSource.ReadDwgFile(dwgPath2, FileShare.ReadWrite, true, null);
        ObjectId id2 = db.Insert("0413_R1_Zvodidla_rozpiska", dbSource, true);
 Can you please share non-confidential drawings and the steps to reproduce the problem ?
Balaji
Developer Technical Services
Autodesk Developer Network
Message 10 of 10
matus.brlit
in reply to: Balaji_Ram
Without API it works.
And it's probably not about the name, because I tried again with renamed dwgs and it failed too. I also tried exactly your code, just to see if the document lock would do any difference, it didn't, it fails with your code too.
Then I examined the drawing and I found out, that there's a lot of blocks, if purged, it works, so it must be some of them causing this problem.
”Boost
