• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    GrzesiekGP
    Block with attributes scaling - what am I doing wrong?
    85 Views, 1 Replies
    11-29-2012 07:49 AM
    Hey,
    I'm trying to make some command which allows me to easily scale blocks.
    I've this code:
                                        BlockReference br = (BlockReference)obj as BlockReference;
                                        br.ScaleFactors = new Scale3d(0.5, 0.5, 1);
     Everything is ok, lines, circles, etc. in block are scalling correctly.
    But I have problem with attributes (look at the image) - attributes are not scaling and their position are not correct.
    Simple command ("scale") is working OK, so what am I doing wrong?
    Please use plain text.
    Distinguished Contributor
    khoa.ho
    Re: Block with attributes scaling - what am I doing wrong?
    11-29-2012 08:23 AM in reply to: GrzesiekGP
    You can find this answer at TheSwamp how to scale the block with attributes: http://www.theswamp.org/index.php?topic=34057.5;wap2 . The key point is using BlockTransform matrix to transform attributes.
    -Khoa
