.NET
Block size
4 REPLIES 4
Ertqwa
2676 Views, 4 Replies
Block size
I want to determine the size of a (non-dynamic non-annotative) block definition (BlockTableRecord). Does a block have a boundry or limits?
For example, if the block would contain a simple square, the size of the block would be equal to the size of the square.
Thank you.
4 REPLIES 4
Alfred.NESWADBA
in reply to: Ertqwa
do you look for that?
Public Overridable ReadOnly Property GeometricExtents As Autodesk.AutoCAD.DatabaseServices.Extents3d
     Member von Autodesk.AutoCAD.DatabaseServices.Entity
[EDIT] sorry, I saw to late that you wrote "block-definition", not block-reference.
So you can either scan through the elements within the blockdefinition or you create one reference virtually and take that reference for .GeometricExtents. [/EDIT]
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Hallex
in reply to: Ertqwa
You can check bound property of block as well:
        [CommandMethod("bsz")]
        static public void BlockRecordSize()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = HostApplicationServices.WorkingDatabase;
            PromptStringOptions pso = new PromptStringOptions("\nEnter block name:");
            pso.AllowSpaces = true;
            PromptResult res;
            res = ed.GetString(pso);
            if (res.Status != PromptStatus.OK)  return;
            string blockname = res.StringResult;
            ed.WriteMessage("\nBock name entered\t{0}\n",  blockname);
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTable bt= tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                if (!bt.Has(blockname))
                    ed.WriteMessage("\nBock \"{0}\" does not exists.\n", blockname);
                    return;
                BlockTableRecord btrec = (BlockTableRecord)tr.GetObject(bt[blockname], OpenMode.ForRead,false);
                Extents3d? bounds;
                 bounds = btrec.Bounds;
                if (bounds.HasValue)
                    Extents3d ext = bounds.Value;
                    double width = ext.MaxPoint.X - ext.MinPoint.X;
                    double height = ext.MaxPoint.Y - ext.MinPoint.Y;
                    ed.WriteMessage("\nBock {0} hase width= {1:f3}; height = {2:f3}\n", blockname, width, height);
                else
                    BlockReference bref = new BlockReference(Point3d.Origin, bt[blockname]);
                    bounds =bref.Bounds;
                    bref.Dispose();
                tr.Commit();
Ertqwa
in reply to: Hallex
Great, both replies are what I am looking for. Ty!
Hallex
in reply to: Ertqwa
Glad you got it working
Cheers 🙂
”Boost
