Block Table Records & Invisible Block
What are all the block table records?
I've got Model Space & Paper Space(Or Layout Space) under control.
I've got two block reference instances of the same block on a drawing.
If I purge the Drawing the older duplicate block reference disappears.
7867 is the older reference that disappears when I use the purge command.
78A7 is the newer reference, I only want to see this one on my extraction of attributes.
What property of the block reference will tell me that it would be purged if I used the purge command?
As I want to detect what's the old block and which one is the current block reference.
Does that make sense what I'm asking here?
The problem is I only want to extract the attributes from the newer block reference.
The old block reference is coming up... how can I filter that out of my loop results?
I know I could just purge the drawing and my problem would be done with.
But I need to do this in a manner that only accesses the drawing from a read-only manner.
