.NET
198 Views, 3 Replies
Block Name
I have iterated thru collected a list of all the nested blocks in a block. My question is how do you capture the block names of the nested blocks?
There is no name property of the blockreference.
thanks
pat
3 REPLIES 3
Dim btr As AcDb.BlockTableRecord = tr.GetObject(BlockID,
AcDb.OpenMode.ForWrite)
btr.Name
Where tr is Transaction, and AcDb is Autodesk.AutoCAD.DatabaseServices
tp
escreveu na mensagem
news:5399887@discussion.autodesk.com...
thanks
pat
I'm protected by SpamBrave
http://www.spambrave.com/
I rectify. To get the name it can be ForRead
AcDb.OpenMode.ForRead)
btr.Name
tp
thanks
pat
i get a warning of not able to cast a blockreference to a blocktablerecord, here is a snippet of my code
Private Sub DynamicLabels(ByRef BlkRefID As ObjectId, ByVal objPanelTag As Object, ByRef Trans As Transaction)
Dim btr As BlockTableRecord = Trans.GetObject(BlkRefID, OpenMode.ForRead)
Dim control As Object
For Each control In Me.grpDynamic.Controls
If TypeOf control Is Panel Then
Dim PanelTemp As Panel
PanelTemp = CType(control, Panel)
If PanelTemp.Tag = objPanelTag Then
Dim lblDynamicName As New Label
Dim lblDynamicDescription As New Label
Dim lblDynamicValue As New Label
Dim lblPanelName As New Label
PanelTemp.Controls.Add(lblPanelName)
lblPanelName.Left = (380 / 2) - (lblPanelName.Width / 2)
lblPanelName.Top = 5
lblPanelName.Width = 100
lblPanelName.Height = 15
lblPanelName.Text = "Block Name = " & btr.Name
lblPanelName.TextAlign = Drawing.ContentAlignment.MiddleCenter
PanelTemp.Controls.Add(lblDynamicName)
lblDynamicName.Left = 5
lblDynamicName.Top = 20
lblDynamicName.Width = 100
lblDynamicName.Height = 15
lblDynamicName.Text = "Name"
lblDynamicName.TextAlign = Drawing.ContentAlignment.MiddleCenter
PanelTemp.Controls.Add(lblDynamicDescription)
lblDynamicDescription.Left = 150 - (lblDynamicDescription.Width / 2)
lblDynamicDescription.Top = 20
lblDynamicDescription.Width = 100
lblDynamicDescription.Height = 15
lblDynamicDescription.Text = "Description"
lblDynamicDescription.TextAlign = Drawing.ContentAlignment.MiddleCenter
PanelTemp.Controls.Add(lblDynamicValue)
lblDynamicValue.Left = 250 - (lblDynamicValue.Width / 2)
lblDynamicValue.Top = 20
lblDynamicValue.Width = 150
lblDynamicValue.Height = 15
lblDynamicValue.Text = "Value"
lblDynamicValue.TextAlign = Drawing.ContentAlignment.MiddleCenter
Next
End Sub
this is how I am calling my "Trans"
Using DB As Database = HostApplicationServices.WorkingDatabase
Using Trans As Transaction = DB.TransactionManager.StartTransaction()
thanks
pat
”Boost
