I want to create an application that intensively uses dynamic blocks, cross checking any new or changed block entity with existing ones.
It needs to be almost instantaneous but the only way I know will be impractical.
Looping through the property collection of each block reference, searching for each parameter then checking for a match.
Is there some sort of database functionality I can use to quickly compare block information?
I think I have worked it out.
I just need to read all the block atts and parameter values into memory on opening the drawing. Along with recording the block IDs.
