.NET
Active Contributor
klahie
Message 21 of 23 (121 Views)
Re: Block-Functions (Select, Explode, etc.)
04-17-2012 03:21 PM in reply to: chiefbraincloud
So Copy+Paste of a blocktablerecord only creates a new instance of this blocktablerecord (called blockreference)?
That means if I paste my beautiful traffic sign 3 times, I have one blocktablerecord and 3 blockreferences on it?
Uuuh, I hope my examiners don't ask bad questions! :smileylol:
Greets
Klaus
chiefbraincloud
Message 22 of 23 (119 Views)
04-17-2012 03:29 PM in reply to: klahie
That is essentially correct.
I would say, you are not Copy/Pasting a BlockTableRecord.
You start out with a BlockTableRecord, which is essentially data only.  It is not visible on screen, and it is not selectable.
You INSERT (Hence the DXF code "INSERT" that you use in the selection filter) a Reference to that BlockTableRecord, Hence BlockReference.
Then you copy that BlockReference and Paste more BlockReferences, all of which point to the same BlockTableRecord.
If you've only had a short crash course on AutoCAD, then I'm guessing your exam must be programming related not AutoCAD related, right?  In which case I would expect your exam questions to be related more to programming and not AutoCAD.
Active Contributor
klahie
Message 23 of 23 (117 Views)
04-17-2012 03:33 PM in reply to: chiefbraincloud
My examiners don't know anything about AutoCAD, it is the programming part which is important. And because of that, I have to do a lot more exception handling, they understand such things. :smileyvery-happy: work for tomorrow... :smileywink:
Thank you for the great support!
Greets
Klaus
You are not logged in.
Ask the Community
