.NET
Active Member
GreenMan415
Message 1 of 2 (242 Views)
Block Attribute Text Color
242 Views, 1 Replies
10-31-2012 04:48 AM
Good Day,
I am looking to go through a whole drawing and change the text color of any block attribute to say 0 as the drawings I am recieving have all the text at a weird color. I was unable to find anything on the forum. I already have a routine that changes text of certain blocks based on layer, but I want this to change the color. Any help would be great! Below is code I used for the layer change I talked about earlier.
publicstaticvoid strFind(string sFind, stringsReplace)
string str = "";
Document document = Application.DocumentManager.MdiActiveDocument;
Editoreditor = document.Editor;
Transactiontransaction = document.Database.TransactionManager.StartTransaction();
try
TypedValue[] valueArray = newTypedValue[] { newTypedValue(0, "TEXT") };
SelectionFilter filter = newSelectionFilter(valueArray);
PromptSelectionResultresult = editor.SelectAll(filter);
ObjectIdCollection ids = newObjectIdCollection(result.Value.GetObjectIds());
foreach (ObjectId id inids)
DBText text = (DBText) transaction.GetObject(id, OpenMode.ForWrite);
if(text.TextString.Contains(sFind))
str =
Regex.Replace(text.TextString, sFind, sReplace);
text.UpgradeOpen();
text.TextString = str;
text.UpgradeOpen();
transaction.Commit();
transaction.Dispose();
khoa.ho
Message 2 of 2 (208 Views)
Re: Block Attribute Text Color
11-03-2012 08:36 PM in reply to: GreenMan415
The following code will change all attribute colors to color index 0 (ByBlock color) of all found block references in the current drawing. If you use a SelectionFilter for the editor to get the selection set based on DxfCodes of TypedValues, you should use DxfCode = INSERT for block references.
[CommandMethod("ChangeBlockAttributeColors")]
public static void ChangeBlockAttributeColors()
    const int replaceColorIndex = 0; // change color to ByBlock
    ChangeBlockAttributeColors(document, replaceColorIndex);
/// <summary>
/// Change all colors of attributes of all block references to a given color index
/// </summary>
/// <param name="document">Document to change</param>
/// <param name="replaceColorIndex">Color ByBlock: colorIndex = 0, Color ByLayer: colorIndex = 256</param>
public static void ChangeBlockAttributeColors(Document document, int replaceColorIndex = 256)
    using (Transaction trans = document.Database.TransactionManager.StartTransaction())
        Editor editor = document.Editor;
        try
            var valueArray = new TypedValue[]
                    new TypedValue(0, "INSERT")    // Filter block references
            var filter = new SelectionFilter(valueArray);
            PromptSelectionResult result = editor.SelectAll(filter);
            if (result.Value == null)
                return;
            var ids = new ObjectIdCollection(result.Value.GetObjectIds());
            foreach (ObjectId id in ids)
                var blockRef = trans.GetObject(id, OpenMode.ForRead) as BlockReference;
                if (blockRef == null)
                    continue;
                AttributeCollection attributes = blockRef.AttributeCollection;
                foreach (ObjectId attributeId in attributes)
                    var attribute = (AttributeReference)trans.GetObject(attributeId, OpenMode.ForRead);
                    if (attribute.ColorIndex != replaceColorIndex)
                        attribute.UpgradeOpen();
                        attribute.ColorIndex = replaceColorIndex;
                        attribute.DowngradeOpen();
            trans.Commit();
        catch (Runtime.Exception ex)
            editor.WriteMessage(ex.Message + "\n" + ex.StackTrace);
-Khoa
You are not logged in.
Ask the Community
