.NET
Active Member
mikecarrico7670
Message 1 of 3 (137 Views)
BeginLISP .net Equivalent
137 Views, 2 Replies
06-18-2012 06:38 AM
I would like to monitor users to get an idea as to which LISP routines are being used in ACAD for cleanup and utilization purposes.  It appears that VBA had a beginlisp event that could be used to handle this, but I can't seem to find any documentation on a similar event or its inclusion in vb.net.  Has anyone found an event that could be used to accomplish this or have any suggestions? Note that I would like to monitor all LISP functions, not a single function. Thanks.
Distinguished Contributor
eljobe
Message 2 of 3 (125 Views)
Re: BeginLISP .net Equivalent
06-18-2012 08:45 AM in reply to: mikecarrico7670
You can still access all the COM stuff through the AcadApplication object.
Active Member
mikecarrico7670
Message 3 of 3 (124 Views)
06-18-2012 08:46 AM in reply to: mikecarrico7670
Solved: BeginLisp is still an even that that can be used for the Acaddocument class via the function call:
"Private Sub LispMonitor(ByVal firstline As String) Handles doc.BeginLisp"
where doc is listed as an Acaddocument variable WithEvents.
Also, there is an event for the Document class called LispWillStart which I imagine works similarly.  Thanks.
You are not logged in.
Ask the Community
