.NET
Batch process and transaction not declared..
4 REPLIES 4
681 Views, 4 Replies
Hi:
I have a command to open some dwg files and print them. I´m using the Sub imprimePDF. When I did the code with (AutoCAD 2011 and VS 2008) , it runs ok but now it´s wrong.
This is the sub
Sub imprimePDF()
   Dim myDWG As Autodesk.AutoCAD.ApplicationServices.Document
   myDWG = Application.DocumentManager.MdiActiveDocument
   Application.SetSystemVariable("BACKGROUNDPLOT", 0)
   Using tr As Transaction =   Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
   Try
       Dim layMgr As LayoutManager = LayoutManager.Current
      Dim loObjId As ObjectId = layMgr.GetLayoutId(layMgr.CurrentLayout)
      Dim lo As Layout = DirectCast(tr.GetObject(loObjId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead), Layout)    error!
end try
end using
end sub
When I´m debugging the code, last sentence produces an error: 'tr not declared'  and I don't know why.
any ideas?
thanks
4 REPLIES 4
augusto.goncalves
The code seems ok, so I'm guessing is something with VS
Can you share a print-screen of VS when the error happens?
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
in reply to: augusto.goncalves
here's the display shows,
thanks,
augusto.goncalves
Actually this is a different issue...
It means that the Transaction and the Layout are not from the same Document.
Augusto Goncalves
ok!, I've erased the green code and added the blue one and  it runs!
 Dim docMgr As DocumentCollection = Application.DocumentManager
        'Using tr As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
        Using tr As Transaction = docMgr(1).TransactionManager.StartTransaction()
 Try
                Dim ps As New PlotSettings(False)
”Boost
