Autodesk.AutoCAD.Windows.PaletteSetStyles.ShowCloseButton
Message 1 of 14
Does any one know why this doesn't actually show a close button on a palette set? Do I need to enable some other method or reference or something before I get an X button on my palette?
Replies (13)
Message 2 of 14
I got an answer from Walmsley. Apparently it is required to mix in some arx code to actully get this to work. One more reason to stick with vba and let Gates keep his junk to himself
Message 3 of 14
What you were told is not true.
There's no need to 'mix some arx code' to get a close button to show on a pallete.
All of my palettes have close buttons on them.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
wrote in message news:5908603@discussion.autodesk.com...
Message 4 of 14
really? can you let me know why my buttons dont appear on the pallette? The only code I can fine is the showclosebutton that a stated above, but it doesn't seem to do anything. Do I need to add something else to make it active?
Message 5 of 14
Are you asking me to guess what your code does?
Please post the relevant parts and I'll have a look.
wrote in message news:5908912@discussion.autodesk.com...
Message 6 of 14
also
Autodesk.AutoCAD.Windows.PaletteSetStyles.ShowminimizeButton
these are in the initialize area of the code. Do you think something else in my code is swithching back off? If not known of the other code is relavant.
Message 7 of 14
Sorry, I'm not interested in playing peek-a-boo.
I said post the relevant parts of the code.
wrote in message news:5909089@discussion.autodesk.com...
also
Message 8 of 14
I'll see if I can post something, but the code actually reads from a database, so all it really says is is stuff like "mdi.asp.feild6 = db.parameter.height" there isn't a whole lot of code to see. I will try to put together a pallette with a little more meat to it with the same inailizer on on the interface. I will get that up next week sometime since I will be out of the office untill Wednesday. Thanks for the help though.
Message 9 of 14
You're misunderstanding what I mean by 'relevant'.
I don't want/need to see code that reads from a database,
only the code that creates and shows the PaletteSet.
wrote in message news:5909269@discussion.autodesk.com...
Message 10 of 14
Sorry Tony, the head programmer won't let me post any code for security reasons. So I guess we will have to figure this out ourselves. Thanks for trying to help us though.
Message 11 of 14
>> Sorry Tony, the head programmer won't let me post any code for security reasons. <<
LOL
There's no security issues with posting a couple of lines of code that creates a paletteset and sets its style.
Message 12 of 14
Tony I got permission to post this:
Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Try
If ps Is Nothing Then
Dim myForm As ModelessForm = New ModelessForm()
ps = New Autodesk.AutoCAD.Windows.PaletteSet("MYPALLETTE")
ps.Style = PaletteSetStyles.ShowTabForSingle
'Wouldn't this statement show the "X" on the Palette:
ps.Style = PaletteSetStyles.ShowCloseButton
ps.Style = PaletteSetStyles.ShowAutoHideButton
ps.MinimumSize = New System.Drawing.Size(300, 500)
ps.Opacity = 65
ps.Add("Search Catalog", myForm)
ps.Visible = True
ps.Dock = DockSides.Left
Catch ex As System.Exception
ed.WriteMessage("Error Creating Palette: " + ex.Message)
End Try
I hope you can see something I cant.
Message 13 of 14
You probably shouln't let the head programmer see this thread.
PaletteSetStyles is a set of flags.
I'll have to assume that you're not familiar with flags and bitwise operatons or how to work with them.
The probelm you have is that you are assigning individual flags to the property, when you should be combining them, like this:
ps.Style = ps.Style Or PaletteSetStyles.ShowTabForSingle
ps.Style = ps.Style Or PaletteSetStyles.ShowCloseButton;
ps.Style = ps.Style Or PaletteSetStyles.ShowAutoHideButton;
The "Or" operator combines the existing flags set in the style property, with the one you pass as the operand.
wrote in message news:5914319@discussion.autodesk.com...
Try
ps.Opacity = 65
ps.Visible = True
End Try
Message 14 of 14
Tony,
That worked just great. We can now hide our pallettes.
Had to modify it slightly to get it to re-appear after the command call. But you solved a big problem for us. Thanks a million.
