• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Autocad with C#
    403 Views, 3 Replies
    03-18-2012 09:49 AM
    Hi.
    I'm a profession Autocad user and I get a help my friend who profession about C#.
    I'm a begineer about AutoCad and programming. I succeed to commenation C# and autocad.  (like DevTv "Hello World")
    I need a C# codes for Autocad 2012 programming.  I mean is that same codes Visual Basic for Application codes and C# codes? (like class)
    Also I need a advice about this subject.
    Thanks for helpings..
    Please use plain text.
    Valued Mentor
    Mike.Wohletz
    Re: Autocad with C#
    03-18-2012 10:00 AM in reply to: ozkan_0712
    Have you downloaded the ObjectARX developer kit and looked at the samples? Also try the following links:
    http://through-the-interface.typepad.com/
    http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ff2566ffd511ff6f8c7ca-48...
    Re: Autocad with C#
    03-18-2012 10:26 AM in reply to: ozkan_0712
    Hi.
    Thanks for helping.
    Yes, We download objectarx Documentation and  Download Complete ObjectARX SDK.
    We looked and studied about it. But I think our problem is that I and my friend work different area. I'm a designer. He is a programmer.
    We made some codes that use Visual Basic for application(in Autocad Tool box) and it worked.But we need to more detail about it.
    For example:
    SolidSelection.Select acSelectionSetAll
    This code is the same use C sharp. ?
    If TumPar.Count <> 0 Then
    With TumPar
    For xp = 1 To .Count
    .Remove (1)
    Next xp
    End With
    On Error Resume Next
    ThisDrawing.SelectionSets("SS01").Delete
    Set SolidSelection = ThisDrawing.SelectionSets.Add("SS01")
    grpCode(0) = 0
    dataVal(0) = "3DSOLID"
    SolidSelection.Select acSelectionSetAll, , , grpCode, dataVal
    N = SolidSelection.Count
    MsgBox "countyourdrawing: " & N
    Moderator
    Alexander.Rivilis
    Re: Autocad with C#
    03-18-2012 02:34 PM in reply to: ozkan_0712
    Posted code is VBA-code. This link can help you to migrate to VB.NET:
    http://through-the-interface.typepad.com/through_the_interface/2010/05/more-translated-autocad-vba-t...
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
