.NET
Active Member
Madmat67250
Message 1 of 12 (507 Views)
Autocad to Excel with events
507 Views, 11 Replies
11-22-2012 11:14 PM
First, sorry for my English...
I'm searching for help according to the Events Handling in vb.net
I'm trying to extract infromations from Autocad (this part of the code is OK), and to insert it in an Excel Cell chosen by the user.
Basicly that's not a problem, using the Getobject method, but in this case I want to use the "click" event to allow the user to tell the program in which cell of the active Excel Workbook the values have to be inserted.
I can't get the Event Handling to work (the dll is started from autocad via netload, and should take control of the excel application).
Is anybody familiar with these events? And can may help me ;-)
Which references have to be loaded in Visual Studio in order to get all this working?
Matthieu
*Expert Elite*
Hallex
Message 2 of 12 (477 Views)
Re: Autocad to Excel with events
11-23-2012 09:20 AM in reply to: Madmat67250
I think you may use Clipboard to make this work
Open Excel book and Acad document
then run this code in AutoCAD, after the any text
was selected, then its content is already in clipboard,
so you could to switch to excel, select your cell and
paste the text by clicking "Paste" from right button click
That's all
#region "System Imports"
using System;
using System.Text;
using System.Windows.Forms;
#endregion
#region "AutoCAD Imports"
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
#endregion
[assembly: CommandClass(typeof(MyProject.MyClass))]
namespace MyProject
    public class MyClass
        public string cellText ="";
         void ed_SelectionAdded(object sender, SelectionAddedEventArgs e)
            ObjectId id = ((SelectionSet)e.AddedObjects).GetObjectIds()[0];
            if (id.ObjectClass.IsDerivedFrom(RXClass.GetClass(typeof(DBText))))
                using (Transaction tr = ((Editor)sender).Document.TransactionManager.StartTransaction())
                    DBText txt = tr.GetObject(id,OpenMode.ForRead, false) as DBText;
                    if (txt == null)
                        MessageBox.Show("NULL");
                        return;
                    System.Windows.Forms.Clipboard.Clear();
                    cellText = txt.TextString;
                    System.Windows.Forms.Clipboard.SetText(txt.TextString, TextDataFormat.Text);
        [CommandMethod("ClipText","ctx", CommandFlags.Modal)]
        public void testCopyClipBoard()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            try{
            ed.SelectionAdded += new SelectionAddedEventHandler(ed_SelectionAdded);
            PromptSelectionOptions pso = new PromptSelectionOptions();
            pso.MessageForRemoval="\nMust be select a single text.";
            pso.MessageForAdding = "\nSelect a single text: ";
            pso.AllowDuplicates = false;
            pso.SinglePickInSpace = true;
            PromptSelectionResult pres = ed.GetSelection(pso);
            if (pres.Status != PromptStatus.OK)
                return ;
            SelectionSet set = pres.Value;
            ObjectId[] ids = set.GetObjectIds();
            if (ids.Length != 1)
                return ;
            catch (System.Exception ex)
                ed.WriteMessage(ex.Message + "\n" + ex.StackTrace +"\n");
            finally
                ed.WriteMessage("\n" + cellText + "\n");
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Active Member
Madmat67250
Message 3 of 12 (466 Views)
11-23-2012 10:07 AM in reply to: Hallex
Thanx for answer, but that's not what I want to do.
I really want to :
1-clic a region in Autocad
2-my program will extract its centroid (X coord and Y coord)
3-make the excel application active
4-make my activeWorkbook active
5-Wait for me to choose a first cell (event handling in the active excel application)
6-Paste X Coord
7-Wait for me to choose a second cell (event handling in the active excel application)
8-Paste Y Coord
9-End of program
At this time I'm at point 4, and everything is working fine, but I don't know how to use events handling to watch excel application, waiting for my cell selection...
I could first select my cell in Excel and easily use ExcelApp.ActiveRange.value="myXCoord"..., but that's not what I'm searching for.
*Expert Elite*
Hallex
Message 4 of 12 (461 Views)
11-23-2012 10:37 AM in reply to: Madmat67250
first I need to know what the language you prefer?
VB.Net or C#?
and also, do you want to use Excel.Interop library or late-binding
to work with them
Active Member
Madmat67250
Message 5 of 12 (454 Views)
11-23-2012 11:02 AM in reply to: Hallex
I definitly only know the vb.net language, and about using  Excel.Interop library or late-binding... I don't really know...
Is there an advantage using the one or the other?
Is this late-binding : "xlApp = CreateObject("Excel.Application")"  ???
If yes, that's common for me to use (I used to write VBA applications), but I'll try the other way if that's better.
By the way, in our office we are using excel 2010 and on some older PCs excel 2003.
Will one of these 2 solutions allow the code to run with both versions?
*Expert Elite*
Hallex
Message 6 of 12 (451 Views)
11-23-2012 11:52 AM in reply to: Madmat67250
I think the late binding is enough to work with both Excel releases
but to write the events will be very difficult for me
Well, will be back in tomorrow,
Active Member
Madmat67250
Message 7 of 12 (428 Views)
11-24-2012 01:43 AM in reply to: Hallex
If it's easier for you to write in C#, I'll convert it with an online converter, like this one : http://www.developerfusion.com/tools/convert/csharp-to-vb/
*Expert Elite*
Hallex
Message 8 of 12 (417 Views)
11-24-2012 07:09 AM in reply to: Madmat67250
Well, try it:
https://dl.dropbox.com/u/18024145/AcadExcelTools.zip
paste to cell is handled event twice, so ignore the second one
and press Cancel to ignore
Tell me when you've copy the code, I will delete it
Active Member
Madmat67250
Message 9 of 12 (384 Views)
11-25-2012 10:15 PM in reply to: Hallex
I've downloaded your file. I'll try it in the morning.
You can delete it.
*Expert Elite*
Hallex
Message 10 of 12 (381 Views)
11-25-2012 10:23 PM in reply to: Madmat67250
OK,
Don't forget to change on your settings
before test
Announcements
Need installation help?
