• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    Autocad objects coloured rgb disappear on mouse over
    168 Views, 10 Replies
    09-24-2012 04:04 AM
    Hi there,
    I if I add an object, let's say a line to the DB.  And colour it with an
    RGB (255, 255, 255) value.  When I hold the mouse over the line,
    it disappears.  Move the mouse off the line and it re-appears.
    Any-one know why?
    Cheers,
    Martin.
    http://www.designprosoftware.co.uk/
    Please use plain text.
    Re: Autocad objects coloured rgb disappear on mouse over
    09-24-2012 04:15 AM in reply to: DesignProQuig
    what happens if you disable SELECTIONPREVIEW?
    - alfred -
    Alfred NESWADBA
    Active Contributor
    09-24-2012 04:19 AM in reply to: alfred.neswadba
    Hi Alfredm,
    no change I'm afraid :-(.
    09-24-2012 04:31 AM in reply to: DesignProQuig
    Hi.
    can you upload this drawing? And what version of AutoCAD plus what background-color do you use?
    - alfred -
    Alfred NESWADBA
    Active Contributor
    09-24-2012 04:35 AM in reply to: alfred.neswadba
    I have my BG set to Black.  After your last post I changed it to red to try it out.  And it works as normal.  But I need the background to be black.
    Ta,
    Maritn.
    09-24-2012 04:39 AM in reply to: DesignProQuig
    Oops, when I open your drawing the line is green (RGB = 87,189,55), do you have a problem with your monitor or gc?
    Try this drawing on another workstation, just to verify!
    - alfred -
    Alfred NESWADBA
    Valued Mentor
    09-24-2012 11:10 AM in reply to: alfred.neswadba
    There is no problem with his monitor.
    This is a bug.
    When SELECTIONPREVIEW = 1 (dash only), objects with RGB colors disappear completely.
    09-24-2012 11:18 AM in reply to: DiningPhilosopher
    >> This is a bug.
    I have set my background to black, I draw a line with true-color 255,255,255, I set the SELECTIONPREVIEW to 1 and to dashed-only-mode ==> when I move my mouse over the line it does not disappear.
    And as the OP stated that he tried also to disable SELECTIONPREVIEW I don't think this is an issue based on that.
    Well, I have SP1.1 installed, maybe that's a difference?
    - alfred -
    Alfred NESWADBA
    Valued Mentor
    09-24-2012 12:31 PM in reply to: alfred.neswadba
    After having a closer look, It may not be a bug in AutoCAD, because it only happens here when using hardware-accelerated graphics. When I disable that, the line is drawn correctly. The system I noticed the issue with is using an ATI Radeon consumer graphics card and driver, so that's most-likely where the problem is.
    Active Contributor
    09-24-2012 01:41 PM in reply to: DiningPhilosopher
    I have just turned hardware accelaration off in options and your right it fixes it.  Not sure how I can leave this off as CAD slows to a crawl.
    Thanks loads & DOH at the same time!
