.NET
Active Member
lfecchio
Message 1 of 4 (147 Views)
Autocad Service with w2003 server
147 Views, 3 Replies
01-09-2013 08:32 AM
Hi!
I did an application using Acad2010 interop thats (same app)::
Works fine in w7 in application form mode.
Works fine in w7 in service mode.
Works fine in w2003 in application form mode.
Doesn't work in w2003 in service mode.
The app is started and when the autocad interop is loadind, alocates around 1/3 of memory for acad.exe and pause.
The user to start the service is the administrator.
The system acount doesn't work too.
Somebody help me?
Distinguished Contributor
djonio
Message 2 of 4 (127 Views)
Re: Autocad Service with w2003 server
01-09-2013 12:15 PM in reply to: lfecchio
Does your service have access to the C++ Runtime that corresponds with VS 2010 on that "w2003" box?
r,
dennis
Active Member
lfecchio
Message 3 of 4 (116 Views)
01-09-2013 02:25 PM in reply to: djonio
I'll verify.
The error returned, only in service mode is:
Falha na recuperação de factory de classes COM do componente com CLSID {6D7AE628-FF41-4CD3-91DD-34825BB1A251} devido ao seguinte erro: 80080005.
I belive that can be access.
Thanks!
Active Member
lfecchio
Message 4 of 4 (110 Views)
01-09-2013 03:21 PM in reply to: lfecchio
I did a test in w7 (service mode) and in first time doesn't work (same error).
After this I changed the user to execute the service and works!
But, in w2003 server this not work.
The autocad was instaled with administrative privileges and I know where I need change theses privs.
You are not logged in.
Ask the Community
