.NET
Autocad Mechanical save as command..
2 REPLIES 2
jgaston
518 Views, 2 Replies
There is some method equivalent to Save As AutoCAD Mechanical 2012?
The Database object has a Save As method, as an argument that defines a file format, but not sure if it matches the format of AutoCAD Mechanical.
2 REPLIES 2
dgorsman
in reply to: jgaston
If you mean convert vertical content to a lower version e.g. Mechanical 2013 to Mechanical 2011 then that can't be done.  You can only downsave DWG format, not vertical content e.g. Mechanical 2013 content in a 2007 DWG format file.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
jgaston
in reply to: dgorsman
Thanks dgorsman
Actually, it is a macro that inserts a block in a batch process. Do not add or modify entities AutoCAD Mechanical. I just want to make sure that the file is saved with the same version with which it was created.
”Boost
