I would like to ask if Autocad LT uses .net API or if .net application created Autocad Map3d will run in autocad Lt?
thanks and regards
If you define "use .NET API" as if LT can load a .NET application, the answer is a big NO, no an application made for Map, nor for Autocad, nor for anything. Autocad LT can't load any type of application, including .NET, Autolisp, ARX C++, no nothing.
Gaston Nunez
