.NET
Autocad Get all elements
5 REPLIES 5
ltf123456
1500 Views, 5 Replies
Hi guys,
How i can browse all objects into an autocad database ???
5 REPLIES 5
Hallex
in reply to: ltf123456
There are many ways to get all objects from db
Here is what you can to use, expand functionality
to your suit:
        [CommandMethod("gall")]
        public void GetAllFromDb()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            ObjectIdCollection ids = new ObjectIdCollection();
            using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
                for (long i = 0; i < db.Handseed.Value; i++)
                    ObjectId id = ObjectId.Null;
                    db.TryGetObjectId(new Handle(i), out id);
                    if (id != ObjectId.Null && !id.IsErased) ids.Add(id);
                foreach (ObjectId id in ids)
                    DBObject obj = tr.GetObject(id, OpenMode.ForRead, false) as DBObject;
                    ed.WriteMessage("\nType of:\t{0}\t{1}\n", obj.GetRXClass().DxfName,id);
~'J'~
ltf123456
in reply to: Hallex
thanks a lot, let me try it
ltf123456
This code is working fine , no problem on that, but what i'm looking for is, how i can get all the objects user does, because i need to export all objects (lines, circles...etc) and in the xml, I will export all properties of those objects (air, length...etc)
thanks a lot of help
Hallex
In this case better yet to use datextraction methods,
search for this on google or on "through the interface" web page:
http://through-the-interface.typepad.com/
there is an example in there
~'J'~
Hallex
Here is my old code I've grabbed from Kean Walmsley
See if this helps
        #region "System"
using System;
using System.IO;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Runtime.InteropServices;
using System.Diagnostics;
using System.Data;
using System.Timers;
using System.Windows.Forms;
#endregion
#region "AutoCAD Imports"
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.DataExtraction;
#endregion
       //' based on Kean Walmsley's example from there:
        //' http://through-the-interface.typepad.com/through_the_interface/2008/04/extracting-data.html
        [CommandMethod("extdata")]
        public void ExtractData()
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            double starttime = 0;
            double endtime = 0;
            System.Windows.Forms.OpenFileDialog dialog = new System.Windows.Forms.OpenFileDialog();
            dialog.CheckPathExists = true;
            dialog.DefaultExt = "dwg";
            dialog.DereferenceLinks = true;
            dialog.Multiselect = false;
            dialog.Filter = "Drawing (*.dwg)|*.dwg|All files (*.*)|*.*";
            dialog.Title = "Select drawing";
           dialog.FilterIndex = 1;
            if (dialog.ShowDialog() != System.Windows.Forms.DialogResult.OK)
                return;
            string fname = dialog.FileName;
            System.Timers.Timer _timer = new System.Timers.Timer();
          _timer.Interval = 1000;
          _timer.Start();
          starttime = DateTime.Now.TimeOfDay.TotalMilliseconds;
            try
                // following datatable easy to write to the any data file (Excel, Access etc)
                System.Data.DataTable dataTable = extractLinesAndTexts(fname);
                 _timer.Stop();
                     endtime = DateTime.Now.TimeOfDay.TotalMilliseconds;
                //' write data to Lines.xml in the Debug folder
                dataTable.WriteXml("LinesAndTexts.xml");
                ed.WriteMessage("\nElapsed time: {0:f2} milliseconds" + "\n" + "Found {1} objects\n" , endtime - starttime, dataTable.Rows.Count);
            catch (System.Exception ex)
                MessageBox.Show(ex.ToString() + "\n" + ex.StackTrace);
            //' Display the  file
            Process.Start("LinesAndTexts.xml", null);
        public System.Data.DataTable extractLinesAndTexts(string fname)
            System.Data.DataTable dataTable = new System.Data.DataTable();
            System.Data.DataTable blkTable = new System.Data.DataTable();
            List<string> tags = new List<string>();
            if (!System.IO.File.Exists(fname))
                ed.WriteMessage("\nDrawing file does not exist.\n");
                return null;
            IDxExtractionSettings es = new DxExtractionSettings();
            IDxDrawingDataExtractor de = es.DrawingDataExtractor;
            de.Settings.ExtractFlags = ExtractFlags.None | ExtractFlags.ModelSpaceOnly;
            de.Settings.ExtractFlags = ExtractFlags.ExtractBlockOnly;
            //'Or ExtractFlags.ModelSpaceOnly
            IDxFileReference fr = new DxFileReference(Path.GetDirectoryName(fname), fname);
            de.Settings.DrawingList.AddFile(fr);
            // Scan the drawing for object types & their properties
            de.DiscoverTypesAndProperties(Path.GetDirectoryName(fname));
            List<IDxTypeDescriptor> types = de.DiscoveredTypesAndProperties;
            // Select all the types and properties for extraction
            // by adding them one-by-one to these two lists
            List<string> selTypes = new List<string>();
            List<string> selProps = new List<string>();
            foreach (IDxTypeDescriptor type in types)
                selTypes.Add(type.GlobalName);
                foreach (IDxPropertyDescriptor pr in type.Properties)
                    if (!selProps.Contains(pr.GlobalName))
                        selProps.Add(pr.GlobalName);
            de.Settings.SetSelectedTypesAndProperties(types, selTypes, selProps);
            // Now perform the extraction itself
            de.ExtractData(Path.GetDirectoryName(fname));
            // Get the results of the extraction
            dataTable = de.ExtractedData;
            if (dataTable.Rows.Count > 0)
                dataTable.TableName = "LinesAndTexts";
                DataRow[] selrows = dataTable.Select("AcDxObjectTypeGlobalName Like '%Line' Or AcDxObjectTypeGlobalName Like '%Text' Or AcDxObjectTypeGlobalName Like '%MText'");
                blkTable = dataTable.Clone();
                foreach (DataRow dr in selrows)
                    blkTable.ImportRow(dr);
                //' commented code lines is just for populating a form listBox control:
                //Dim columns As String() = New String() {"AcDxObjectTypeName"}
                //Dim dvw As DataView = blkTable.DefaultView
                //distinctTable = dvw.ToTable(False, columns)
                //Dim bnames As New List(Of String)()
                //For Each dr As System.Data.DataRow In distinctTable.Rows
                //    Dim bname As String = dr(0).ToString()
                //    If Not bnames.Contains(bname) Then
                //        bnames.Add(bname)
                //    End If
                //Next
                //Me.lst.DataSource = bnames'' <-- to fill ListBox only
                //lst.SelectedIndex = -1'' <-- set selected items to nothing
            return blkTable;
~'J'~
”Boost
