Autocad Database Save ?
Dear all,
Here i have one question,
while using myDBt.Save() program is terminating,
Is there only way to use myDBt.saveas()
Please give me suggession...
{code}
PublicSub text_replace_CAD(ByVal fname AsString, ByVal old_string AsString, ByVal new_string AsString)
Dim myTranst AsDatabaseServices.Transaction
Dim myTransMant AsDatabaseServices.TransactionManager
Dim myBTRt AsBlockTableRecord
Dim myBTt AsBlockTable
Dim myDBt AsNew DatabaseServices.Database(False, True)
If fname.ToUpper.EndsWith("DWG") Then'myDBt.ReadDwgFile(fname, IO.FileShare.ReadWrite, True, "")
myDBt.ReadDwgFile(fname, FileShare.ReadWrite,
True, "")
EndIf
myTransMant = myDBt.TransactionManager
myTranst = myTransMant.StartTransaction
myBTt = myDBt.BlockTableId.GetObject(OpenMode.ForWrite)
myBTRt = myBTt(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForWrite)
Dim myBTEn AsBlockTableRecordEnumerator = myBTRt.GetEnumerator()
WhilemyBTEn.MoveNext
Dim acEnt As Entity = CType(myTranst.GetObject(myBTEn.Current, OpenMode.ForWrite), Entity)
SelectCaseacEnt.GetType.Name.ToUpper
Case"DBTEXT"Dim dbt AsDBText = acEnt
dbt.TextString =
"Mabani"Case"MTEXT"Dim mtb AsMText = acEnt
mtb.SetContentsRtf(
"Mabani")
Case"RotatedDimension".ToUpper
Dim mtb AsRotatedDimension = acEnt
mtb.DimensionText =
"Mabani"EndSelectEndWhile
myDBt.Regenmode =
True
myDBt.CloseInput(
True)
myTranst.Commit()
myDBt.SaveAs(fname, DwgVersion.Current)
myDBt.Save()
myTransMant.Dispose()
EndSub
{code}
norman.yuan
Yes, this is by design: you must use Database.SaveAs() to save changes made to the database.
Database.Save() method is inherited from the API interface under the hood and is not implemented (that is, if you call it, it raises exception like "...not implemented...".
Norman Yuan
Drive CAD With Code
Did you try to Lock the document before making any changes in the database and saving?
using (DocumentLock docLock = doc.LockDocument())
	you code here
Ertqwa
Database.Save() is not implemented and always gives an error, as I understand it.
I save a database like this (C#):
// Save as tmp file.
objDatabase.SaveAs(ChangeEnd(strPath, "tmp"), DwgVersion.Current);
// Delete bak file.
if (System.IO.File.Exists(ChangeEnd(strPath, "bak")))
{ System.IO.File.Delete(ChangeEnd(strPath, "bak")); }
// Rename current dwg to bak file.
System.IO.File.Move(strPath, ChangeEnd(strPath, "bak"));
// Rename temp file to dwg file.
System.IO.File.Move(ChangeEnd(strPath, "tmp"), strPath);
The function ChangeEnd() you'll have to write yourself, I use it to change the extensions (C#):
        public static string ChangeEnd(string strSource, string strEnd)
            // Change the last characters from string strSource into strNewExt.
            // strSource.Length must be >= strNewExt.
            // On error, it returns strSource.
            string strResult;
            try
                if (strSource == null || strEnd == null) { return strSource; }
                if (strSource.Length < strEnd.Length) { return strSource; }
                if (strSource.Length == strEnd.Length) { return strEnd; }
                strResult = strSource.Substring(0, strSource.Length - strEnd.Length);
                strResult += strEnd;
                return strResult;
            catch
                return strSource;
Hallex
Spoiler
Take a look at String.EndWith method,
then you have to use like this:
if (FileName.EndWith(".bak")
//do your mojo here
HTH
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
tyronebk
Ertqwa, you could also simplify your functions using some of the methods available in System.IO.Path.
