.NET
Active Contributor
xdbk07
Message 1 of 5 (188 Views)
Autocad 2012 and 2013
188 Views, 4 Replies
05-14-2013 01:15 AM
Hi All,
Autocad 2012 and 2013 both run under NET FRAMEWORK 4.0. So, is there a way to build *.dll file for them?
mzakiralam
Message 2 of 5 (177 Views)
Re: Autocad 2012 and 2013
05-14-2013 04:10 AM in reply to: xdbk07
Your question is not so clear. What are you looking for actually?
arcticad
Message 3 of 5 (164 Views)
05-14-2013 07:05 AM in reply to: xdbk07
if you want to make an application that loads into AutoCAD is has to be a .dll file.
You would create a class library project and load it.
The fact that is uses .net 4.0 doesn't matter. .
(defun botsbuildbots() (botsbuildbots))
Active Contributor
xdbk07
Message 4 of 5 (157 Views)
05-14-2013 08:03 AM in reply to: xdbk07
I want to build a *.dll file under Net framework 4.0 foundation. And It can work OK both Autocad 2012 and 2013.
Is there any way?
Valued Contributor
amanero
Message 5 of 5 (156 Views)
Maybe you are talking about making one compilation for both versions?
If you are, I think it is not possible because of the "extra" reference needed in 2013 version "accoremgd.dll", you will need to make two proyects instead only one.
Luis Alberto Manero, Geograma.com
You are not logged in.
Ask the Community
